fan clutch help now !!!!!!!!!!!!!!!!!!!!!!!1
Old Dec 15, 2007 | 03:53 PM
dowale41's Avatar
dowale41
Junior Member
Default fan clutch help now !!!!!!!!!!!!!!!!!!!!!!!1
does anyone know how to remove the fan clutch on an 2004 ram 5spd
Old Dec 15, 2007 | 09:54 PM
MikeHTally's Avatar
MikeHTally
Default RE: fan clutch help now !!!!!!!!!!!!!!!!!!!!!!!1
Best way is dynamite! You need to get a spanner which will allow you to hold the water pump pulley still while you rotate the water pump nut CCW. Some folks rig up a metal strap or something to hold a pin in the pump pulley, but save yourself the aggravation. If the truck is still driveable, go to NAPA or Advance Auto. The spanner probably isn't terribly expensive. I had this same problem when changing to my e-fan. I wrestled with it for a couple of hours and gave up. I could not get the water pump pulley nut off. Finally went to a shop and they had it off in no time. There is no substitute for the proper tools. Good luck.
Old Dec 16, 2007 | 09:05 PM
MikeHTally's Avatar
MikeHTally
Update -- I checked around a bit today... Advance Auto Parts doesn't sell the spanner. They have a kit of tools you can buy and then return for a full refund. Here it's $60. NAPA didn't even know what I was talking about. That's about the fifth time I've tried to buy something at NAPA where they had no idea what I was talking about.
Old Dec 16, 2007 | 09:17 PM
JD1500's Avatar
JD1500
That is weird, the NAPA here, is really good. Some realy car guys, and a body guy own it though..
But yeah, get yourself a spanner, you should be able to find one somewhere for about 20 bucks, saves you about 3 million hours of labor
Old Dec 17, 2007 | 09:18 AM
kregier's Avatar
kregier
A really big wrench and a hammer. And no, I'm not kidding. Put the wrench on, hit the end with the hammer. The clutch will slip, but it does work. Just reposition the wrench and keep going. That's how I got mine off. Took about 10 good hits.
Old Dec 17, 2007 | 11:45 AM
MongoDV8's Avatar
MongoDV8
I use an air chisel. A couple 2 second bursts and it looesens right up without hardly any damage to the nut. I would buy a spanner wrench if I could find one. There is no substitution for the right tool.
Old Dec 19, 2007 | 07:28 AM
MikeHTally's Avatar
MikeHTally
I have one of these coming. http://www.amazon.com/exec/obidos/AS...sou0b402895-20Wish I'd had it when I installed my e-fan. Would've paid for itself then.
Old Dec 19, 2007 | 07:53 AM
studlyblueiz's Avatar
studlyblueiz
Someone should start passing one around. We do this a lot on a Jeep forum. We'll pass tools we'll maybe only use once or twice and just keep it in circulation. Just start a thread for specialty tools and post whenever you need the tool. All you pay for is the shipping. It'll save everyone money.
Old Dec 19, 2007 | 10:24 AM
tdmopar59's Avatar
tdmopar59
ORIGINAL: MikeHTally
i coulda used that!! lol dodge doesnt want people takin off fans any other way! LOL
Old Dec 19, 2007 | 05:59 PM
oefootball_70's Avatar
oefootball_70
has anyone done a e-fan DIY write up? I would like to see one, because I really wanna do it but I can't figure out how to do everything.
