leveling kit
Old Dec 18, 2007 | 12:52 AM
senselesscreationz's Avatar
senselesscreationz
Default leveling kit
ive searched and searched and cant seem to find a direct answer its either a hit or a miss... im lookin for the max size tire i can run on a 2005 ram 1500 4x4 with the tb crank... im seein that i can run 33 1250 17 but can i go any bigger or is that the biggest size i can run and the offset that i would need... plz help....[&:]
Old Dec 18, 2007 | 01:26 AM
tdmopar59's Avatar
tdmopar59
Default RE: leveling kit
yea... you should run a 33 if you really wanted to run a 35 i have been told its possible... i wouldnt do it... No flex you will prolly rub some....
Old Dec 18, 2007 | 08:10 AM
HammerZ71's Avatar
HammerZ71
ORIGINAL: tdmopar59
+1
35's for looks but next to no extra room for any flexing, so anything but mild off road use would be out...
Old Dec 18, 2007 | 05:00 PM
senselesscreationz
[align=left]im not going to be going offraod maybe once and a while, but if i run the 35's should i regear?? and what offset would i need on the rims to run the 33's or the 35's
[/align]
Old Dec 18, 2007 | 05:04 PM
senselesscreationz
also how much clearance would i have with the 33's and the 35's?
Old Dec 18, 2007 | 06:08 PM
HammerZ71's Avatar
HammerZ71
-12 offset and about a 4.5" backspace would be good. You would just barely clear 35's and clear 33's very easily. If your stock gears are 3.92 you would just about still be in spec with 33s. If you have the ****ty 3.55s then opt for 4.10s. With 35's you really want 4.56 gears.
Old Dec 18, 2007 | 06:34 PM
senselesscreationz
would i be ok running a 315/70/17?? i have the stock 20's on now but i hate them and want to get rid of them.
Old Dec 18, 2007 | 06:40 PM
senselesscreationz
http://www.4wheelparts.com/prodDetai...tNo=NIT200-430
would they work??
Old Dec 18, 2007 | 08:34 PM
Lash's Avatar
Lash
Thats what I have on my truck....no lift, level,or t-bar crank....clear no problem.They are a tad taller than a 33" tire. You can see pics of them in my other thread.
tirepackage.com has some great deals on rims/tires. I got those nitto's for $160 each.
