Full-body vinyl wrap
Old Dec 21, 2007 | 12:04 PM
SonOfSparda's Avatar
SonOfSparda
Default Full-body vinyl wrap
Is it possible to put it on by yourself? Is it hard to get rid of air bubbles?
http://www.uploadgeek.com/uploads456/0/greenTruck.png
Does the above vinyl wrap look in any way familiar to you? Do you know of any wrap that has a yellow design in the center or yellow lettering or symbols on part of it?
Old Dec 21, 2007 | 12:15 PM
John  M's Avatar
John M
Default RE: Full-body vinyl wrap
That looks like a normal camo print to me.
If you're not a professional you should not wrap a vehicle yourself. It'll turn out pretty badly and waste an expensive amount of vinyl. A full vehicle wrap is not cheap - it'll be several thousand dollars. Find a sign/graphics shop near you to do it.
Old Dec 21, 2007 | 12:52 PM
JD1500's Avatar
JD1500
Yeah, i used to work at a sign shop, take it to a viny place. on a full wrap there is a lot of special cuts and etc to get rid of bubbles and wrinkles
Old Dec 21, 2007 | 01:07 PM
SonOfSparda
It looks pretty bright for a regular camo print. Like a bright green instead of the typical olive. Have you ever seen a full-body jungle or forest (not camo) design?
Old Dec 21, 2007 | 01:10 PM
JD1500's Avatar
JD1500
Yeah, i have seen realtree and advatage camo, not sure where they were from google it. I know a lot of people just have the camo fender flares, and rocker panels put on, with camo vent visors, looks good and is easy to do that yourself. alot of straight lines.
I think cabelas carry's some of the trim and rocker panel vinyl
Old Dec 21, 2007 | 02:26 PM
Parts/Service's Avatar
Parts/Service
This is an Excursion that Me and another guy at work did. It is a full wrap including the roof. It was time consuming but not as hard as you might think. A good heat gun helps. Also alot of planning to make the openings line up to look seamless. We used 15 sheets of Real Tree Advantage. Each sheet is about $75.00. They make 2 kinds, removable and non-removable. buy theremovable, it is easier to remove/adjust if you put it on wrong. Try this site for the good stuff.>>>>>>> http://camoclad.com/
Old Dec 21, 2007 | 03:35 PM
#Red's Avatar
#Red
Looks great but I would not want to do it. This would be a “cut the check†type job for me. I’ve watched them decal race cars and it is a lot of work and they have to look perfect. Red
Old Dec 21, 2007 | 03:50 PM
tdmopar59's Avatar
tdmopar59
thats pretty sweet!! i dont have the patience to do it myself though.. LOL
Old Dec 21, 2007 | 03:56 PM
Kev_n_AZ's Avatar
Kev_n_AZ
thast 1 slick job!
Im thinkin I should do body fix on mine and the wrap it like that !!!
(of course, I wouldnt have to paint it again )
