I WAS GONNA CHANGE MY PLUGS BUT THEN.........
Old Dec 22, 2007 | 01:04 PM
7floorsofhell's Avatar
7floorsofhell
Default I WAS GONNA CHANGE MY PLUGS BUT THEN.........
whats the oem plug that goes in these puppies. i've been running NGK and i'm thinking of trying that champion double platinum. whats good in the 5-8 dollar a plug range?
Old Dec 22, 2007 | 01:30 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: I WAS GONNA CHANGE MY PLUGS BUT THEN.........
Champs are OEM and VERY recommended.
However given your SC you should run a cooler spark. Do some reserch but find a cooler spark than OEM. I am running Bosch in my SRT. If your spark is to hot you stand the chance of pre-ignition which is VERY bad with a FI system.
Old Dec 22, 2007 | 01:33 PM
MoparRob's Avatar
MoparRob
And dont they say that the Hemis dont like platinum??
Old Dec 22, 2007 | 01:34 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: MoparRob
They run cooler, he needs a cooler spark with FI if he likes his internals.
Old Dec 22, 2007 | 02:47 PM
John  M's Avatar
John M
Buy a cooler range plug but NOT platinum.
Platinum is good for longevity -- it lets automakers specify those 100k mile tuneup intervals. It is crap for spark though, which is what you need.
Go with a good copper plug. I've run NGKs in forced induction setups for 15 years and that's what'll go in my truck when I do the plugs & wires soon.
Old Dec 23, 2007 | 12:47 AM
tdmopar59's Avatar
tdmopar59
i have always been told Copper champions... i also heard that with f/i you just have to gap them differently....
Old Dec 23, 2007 | 12:53 AM
MikeHTally's Avatar
MikeHTally
With the boost you're using, NGK 4306s will probably do nicely, maybe even cooler.
Old Dec 23, 2007 | 01:47 AM
JimmyDiablo's Avatar
JimmyDiablo
I WAS GONNA CHANGE MY PLUGS BUT THEN Let me finish the sentence.....
I traded my gasser in for a diesel[8D] **Diablo runs like hell**
Old Dec 23, 2007 | 03:06 AM
John  M's Avatar
John M
ORIGINAL: tdmopar59
If it misses under boost then a smaller gap would help. However, you want to run the widest gap you can without causing a miss so if it works at that boost with the OEM gap, leave 'em there.
I imagine it'd be a PITA to re-gap 16 plugs too!
Old Dec 23, 2007 | 10:55 AM
06Heminightrunner's Avatar
06Heminightrunner
I was told by a number of people to only run platinums in the hemis. because the ignitions system voltage is so high that it will just burn out a regular plug, and that's why they say to do them at 36,000 or what ever. not cause there carboned up but becasue there worn out from the voltage. i don't know how much truth there is to it but that's what i've heard. also was told if i was going to switch plugs to spend the money and go with the NGKs. i personaly run those in everything i own besides my truck. i'm not a big fan of champion plugs. have had problems with them incars and toysin the pass
