Anyone ever got a rock in the brakes?
Old Dec 23, 2007 | 07:31 AM
jrudicel's Avatar
jrudicel
Default Anyone ever got a rock in the brakes?
Drove truck a week or so ago. Had alot of rain/snow mix that day. When truck was parked, everything was fine. Went back a day or two ago to run to town, and when i hit the brakes it made a grinding like noise. I thought it was ice where it had sit. I hit the brakes real hard once, and now it doesnt do it under minor braking but only under harder braking. Sounds like the front passenger side ... truck is a 07 QC with 1800 miles. Rotors look fine and not scored, so ? Havent popped wheel off yet...just wondering if there was any common problems on these, or if a rock is possible? With those 20 inch wheels , they look pretty much open for whatever. Anyone experience this?
Old Dec 23, 2007 | 09:05 AM
ce2flaco's Avatar
ce2flaco
Default RE: Anyone ever got a rock in the brakes?
I have gotten rocks in between the dust shield and the rotor. You can take the wheel off or try to get a finger tip on the dust shield and pull it out far enough to let the rock fall out. The are indentions in the shield than can trap a rock rather than let it travel out the other side as the rotor turns.
Good luck
Old Dec 23, 2007 | 06:37 PM
jrudicel's Avatar
jrudicel
Thanks man. Will check that out. Actually, now that you say that, it does sound like the brake shield making noise as well...
