gascap
Old Dec 23, 2007 | 10:56 AM
mxmancr250's Avatar
mxmancr250
Default gascap
That's what is says on my odometer display. It came on about 180 miles after I had filled up already. I checked that cap and it is on tight, I filled up last night and it still says gascap on my display. Any ideas? 07 1500 4.7 4x4.
Old Dec 23, 2007 | 11:05 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: gascap
Might need a new one...if it doesn't seal correctly it'll throw the code you're getting.
Old Dec 23, 2007 | 11:42 AM
The Peddler's Avatar
The Peddler
Default RE: gascap
ORIGINAL: SeVeReDiStOrTiOn
+1
Old Dec 23, 2007 | 11:43 AM
Vandersnoot's Avatar
Vandersnoot
Default RE: gascap
Also, did you make sure that it clicked? On my last vehicle I would have the same problem if i didnt rotate the gas cap until it "clicked" 3 times. Just my 0.02
Old Dec 23, 2007 | 12:02 PM
tdmopar59's Avatar
tdmopar59
Default RE: gascap
yea i would take it off and tighten it all the way if that doesnt work go to the stealership and a new gas cap isnt as expensive as you would think...
Old Dec 23, 2007 | 12:09 PM
Parts/Service's Avatar
Parts/Service
Default RE: gascap
Issue Description:
Issue 1: Do NOT order a Gas Cap if the ONLY customer complaint is a Loose Gas Cap message/indicator. The Gas Cap is/was most likely loose after the last re-fueling event. Simply tighten the Gas Cap and the system will re-run the EVAP test and clear the message; or, tighten the Gas Cap and then use the DRB III to perform the “Clear PCM Batt Disconnect" function or the StarSCAN to perform the "Reset ECU" function. Refer to Service Bulletin 14-001-06 for more information. >>>>>>> http://dodgeram.info/tsb/2006/14-001-06.htm
New part # 5278632AG Cost about $12.00
Hope this helps....
Old Dec 23, 2007 | 12:35 PM
mxmancr250's Avatar
mxmancr250
Default RE: gascap
Sweet, the gas cap is tight, so I will disconnect the battery to clear the code and see what happens.
Old Dec 23, 2007 | 04:59 PM
typiece's Avatar
typiece
Default RE: gascap
i had the same problem with mine and it was in the dealership for a week because they couldn't figure out the problem and why the gascap light wasn't going off. finally, they just had to replace the whole gas line and tank. they "smoked it out?" and found a small leak that was the cause. was a pain, but problem was fixed and covered under warranty.
