sludge
Old Jan 4, 2008 | 10:53 AM
  #21
mfs212's Avatar
mfs212
Default RE: sludge
No....it was just getting his thoughts on my previous post...he more or less said the same thing as TD... We really need to know more about the sludge...
Old Jan 4, 2008 | 12:05 PM
  #22
bdhuntr's Avatar
bdhuntr
Default RE: sludge
ORIGINAL: dieseldoc1
did u buy the truck used? if so u may be battleing the previous owners stupidity, like runnig penzoil and never changing it.
Don't you mean Quaker State?
Old Jan 4, 2008 | 02:07 PM
  #23
MikeHTally's Avatar
MikeHTally
Default RE: sludge
Probably.
Old Jan 4, 2008 | 03:48 PM
  #24
HammerZ71's Avatar
HammerZ71
Default RE: sludge
MFS212:
If you still have it, cut & paste my pm to you in this thread so that Panama Man doesn't have a hissy on us...
Old Jan 4, 2008 | 03:59 PM
  #25
mfs212's Avatar
mfs212
Default RE: sludge
10-4
Old Jan 4, 2008 | 04:00 PM
  #26
mfs212's Avatar
mfs212
Default RE: sludge
Sound theory, I don't see any reason why it wouldn't be possible. But this guys problem is out of my area, so I have not responded. I'm just an old 4x4 off road guy with 20+ years of 4x4'sand lifted trucks. I'm more of a bolt on mod & lift kit guy. I leave the actual engine innards to the real mechanics. My pop wasone, and my uncle retired a 38 year Chrysler mechanic, but with me it's just a hobby.
One thing I do know though, is next time he changes the oil, he's got to drop the pan. This is the only way he'll know if he's just sloshing around the old sludge or he's starting clean and making sludge as he goes. If it's the latter, then he can start looking at your theory...
Old Jan 4, 2008 | 04:11 PM
  #27
HammerZ71's Avatar
HammerZ71
Default RE: sludge
mfs212: Thanks
NYPANAM42: The previous post is my pm to him, happy?[&:]
Old Jan 4, 2008 | 05:30 PM
  #28
Gone Fishin's Avatar
Gone Fishin
Default RE: sludge
THERE IS SOMETHING ELSEGOING ON HERE OTHER THAN THE OBVIOUS.
Make sure you are getting proper crankcase ventlation
Do a leak down test on the cooling system.
Sounds to me like he's getting antifreeze in the oil for whatever reason and its sludging up, possibly due to short driving distance. Excessive water in the oil will destroy an iron pump in short order.
Also change gas stations. If you use the same one religously, you may be getting some kind of contamination from the fuel thats draining past the rings into your oil causing the sludge ( I know this is a stretch, just brainstorming for causes).
Also, are the any PCM codes being stored---maybe check this first!!!!
Old Jan 4, 2008 | 07:37 PM
  #29
NYPANAMA42's Avatar
NYPANAMA42
Default RE: sludge
ORIGINAL: HammerZ71
mfs212: Thanks
I knew that, but i figured i'd break your *****........you know you aren't yourself until you get to spew out some sarcasm...[8D]
Old Jan 4, 2008 | 07:38 PM
  #30
NYPANAMA42's Avatar
NYPANAMA42
Default RE: sludge
[quote]ORIGINAL: HammerZ71
mfs212: Thanks
[/quote
