code p0441
Old Jan 11, 2008 | 09:54 PM
Mattcmdr's Avatar
Mattcmdr
Default code p0441
soo i go to start my truck up and the check engine light is on.......ofcourse. soo i go home and read the code then get on all data and see that it is about the evaporation emission control canister. i read on there that it could just be a pinched return or sending line or a bad pump or a number of other things. anyone ever had this code pop up and if soo what was the problem it ended up being???
Old Jan 11, 2008 | 11:41 PM
Mattcmdr's Avatar
Mattcmdr
Default RE: code p0441
anything????
Old Jan 11, 2008 | 11:44 PM
Dire Wolf's Avatar
Dire Wolf
ORIGINAL: Mattcmdr
anything????
Common problem, at least with the 03's. Check the small cheap things first. I got the code and it went away then came back few days later, I spent $10 on a gas cap and it solved it for now. Good luck.
Old Jan 12, 2008 | 08:42 AM
Mattcmdr's Avatar
Mattcmdr
the emmisions testing placejust mademe go get a new one so maybe that has something to do with it
Old Jan 12, 2008 | 12:05 PM
Gone Fishin's Avatar
Gone Fishin
Matt,
Another area to check is the rubber hose connections to the evaporative system. The canister and connection lines are located behind the driver up in the frame rails, also the solenoid valve is located next to and below the battery--at least on mine it is. Small leaks in these rubber lines can cause the same troubles. Quite often you'll get a "small evap leak" code, and if they are bad enough, a "large evap leak" code. Given the age of your truck, and the fact that the rubber lines are just plain rubber lines, nothing special, I wouldn't be surprised. I plan on doing mine this summer with silicone lines as mine is nearing the 70K mark.
Old Jan 12, 2008 | 12:46 PM
Mattcmdr's Avatar
Mattcmdr
yea thats what ALDATA said it probly was soo i was planning on checking that once i got off work. i checked the hoses that are up in the engine bay as it was too dark to get up and under the truck lastnight.
