keyfob
Old Jan 13, 2008 | 11:52 PM
hemiman07's Avatar
hemiman07
Default keyfob
I know this has been asked before but, I reprogrammed my keyless remote to unlock all four doors with one push of the button, now I want it to go back to the stock setting. How do I do this.
Old Jan 14, 2008 | 07:09 AM
MikeHTally's Avatar
MikeHTally
Default RE: keyfob
Just re-do the procedure isn't it? It'll be in the manual. Leaving for work soon, don't have time to look it up.
Old Jan 14, 2008 | 12:14 PM
Parts/Service's Avatar
Parts/Service
Default RE: keyfob
Hope this helps....DAVID
UNLOCK SEQUENCE The unlock sequence can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To toggle between Driver door first and Unlock all doors function: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To toggle this feature, repeat the above procedure.
Old Jan 14, 2008 | 01:06 PM
MikeHTally's Avatar
MikeHTally
Default RE: keyfob
What he said.
Old Jan 14, 2008 | 04:46 PM
rayk3's Avatar
rayk3
Default RE: keyfob
I didn't know that the key fobs could be programmed to open all 4 doors at the same time. So if I follow this procedure, it will allow all 4 doors to be unlocked at the same time?
Old Jan 14, 2008 | 07:24 PM
Parts/Service
Default RE: keyfob
ORIGINAL: rayk3
Yes Sir...
Old Jan 14, 2008 | 09:38 PM
texas_rebel_1980's Avatar
texas_rebel_1980
Default RE: keyfob
anyway to stop the horn from chirping on lock? i drove my neighbors bat**** one day trying to figure it out and just gave up.
Old Jan 14, 2008 | 10:16 PM
Parts/Service
Default RE: keyfob
HORN CHIRP DISABLING / ENABLING The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the horn chirp feature: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. 7. Test the horn chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the horn chirp feature, repeat the above procedure.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING The optical chirp can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the optical chirp feature: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. 7. Test the optical chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the optical chirp feature, repeat the above procedure
Old Jan 15, 2008 | 10:43 AM
DaHipaKea1313's Avatar
DaHipaKea1313
Default RE: keyfob
Hey I was wondering about reprograminga key fob, we tradedourSebring forour Ramback in 2005 when I came home on mid-tour leave but only had one of the fobs at the time. It had stopped working, probably needed a new battery, but I was in Iraq and the wife justswitched the 2 fobs outso she had one. We found the extra Sebring key fob this past Sep while I was packing up to come back over to play in the sand again.
So I was wondering can it be programed to work withour Ram or do I need to just go get another one from the Dodge dealer??
Old Jan 15, 2008 | 01:06 PM
MikeHTally's Avatar
MikeHTally
Default RE: keyfob
Worth a shot... You might compare the numbers on the back of the fob. The part number and the FCC number don't have to match exactly, but I think they have to be close.
