Parking lights out
Old Jan 15, 2008 | 08:24 PM
Brandangd69's Avatar
Brandangd69
Default Parking lights out
First I'd like to say hey to everyone, Im new to the Forum. I'm having an issue i just cannot figure out. My rear Driver side tail light is out. I replaced the bulbs and there aren't any blowen fuses. The break, reverse and signal lights all work fine. All other lights work fine when theswitch for the lights is all the way turned on.When the switch is set to parkinglights which is the middle setting. Thattail light still doesn't work but now the front drivers side parking light doesn't workbut the signal does? This is for a Quad cab 2002 ram. Anyone have any suggestions???
Old Jan 15, 2008 | 09:37 PM
Brandangd69
Default RE: Parking lights out
Nobody???
Old Jan 15, 2008 | 10:10 PM
HammerZ71's Avatar
HammerZ71
Swap out the parking light relay in the fuse box under the hood. About a $7 part at auto parts store or $9 at the dealer...
Old Jan 15, 2008 | 10:16 PM
Parts/Service's Avatar
Parts/Service
Also check fuse #15 (50amp) in the power distribution center under the hood. Oh, and welcome to the forum.
Old Jan 16, 2008 | 04:15 PM
braaap11889's Avatar
braaap11889
Having the same problem. DO NOT get a new switch its not that.
Old Jan 16, 2008 | 07:40 PM
N85RE's Avatar
N85RE
Yea i,ve been there , done that
Old Jan 16, 2008 | 08:49 PM
Brandangd69
I would think that if it was a that 50 amp fuse then both tail lights would be out, but who knows its worth a shot anyways. Thanks everyone for the replys
Old Jan 17, 2008 | 03:05 PM
Redram05baby's Avatar
Redram05baby
I HAD The Same Problem.
Mine Started Intermittent, Then Eventually Just Failed
It Ended Up Being The Actuall Ballas (No CLue How To Spell That) That Holds The Bulb. The Contacts Were Corroded On The Backside. Look At The Connections, I Simply Cleaned The Connections and It Worked.
Old Jan 17, 2008 | 03:19 PM
oefootball_70's Avatar
oefootball_70
same prob, check fuse. I think it was 28 or in that area. It is a 10 fuse. fixed it right away.
Old Jan 17, 2008 | 06:31 PM
Brandangd69
Ok so I replaced the Park light Relay and the 50 amp park light/tail light fuse as well as the 10 amp fuse and still the problem has not been fixed. Thank you guys for your help, keep the suggestions coming
