superchargers/turbochargers
Old Jan 31, 2008 | 04:00 PM
Big#44's Avatar
Big#44
Default RE: superchargers/turbochargers
ORIGINAL: oefootball_70
you will need the computer from the dakota new everything, new tranny. Its not worth it to do the swap, you would be better blowing up the 3.7 and dropping a chevy 350 in it.
even if he "blew up the 3.7L" and dropped a 350 he would still need to swap everything. How would that be better??
Old Feb 1, 2008 | 12:53 AM
oefootball_70's Avatar
oefootball_70
Because there are 350's readily available for a lot cheaper and you can get a cheaper transmission that would bolt up from a late model chevy and it would cost you a lot less. Because 5.7 hemi is really expensive to buy with everything you would need. The 350 isn't run with a comp so you wouldn't need to re wire everything.
