PCM failure
Old Jan 25, 2008 | 07:50 PM
dp1973's Avatar
dp1973
Default PCM failure
I have a 2002 Ram 1500 with a 4.7. Ihave a trouble code P0601 and from what information I've found on the net I will have to replace my PCM. The dealer's price is $715 part and $200 labor. Is this my only option? The only PCM's I can find on the net are for deisels.
Old Jan 25, 2008 | 08:02 PM
Parts/Service's Avatar
Parts/Service
Default RE: PCM failure
P0601 is a code for "PCM internal controller failure" Thats not good. The only fix is to replace the PCM. Is yours a automatic or manual trans?
Old Jan 25, 2008 | 10:47 PM
dp1973's Avatar
dp1973
Automatic
Old Mar 28, 2008 | 02:41 PM
Swanny's Avatar
Swanny
Did you replace the PCM? From what I've heard that's the common fix is to replace the PCM - http://www.obd-codes.com/p0601
Old Jul 30, 2008 | 11:02 PM
Kevno6's Avatar
Kevno6
Just got the same engine code on my 02 Sunday. Does anyone know where the pcm is located that has to be replaced. Is this covered under some kind of warranties. Cheapest I can find is $600 not from dealer. I have heard you can get them from the junk yard and have them flashed as long as it is the same year.
Old Jul 30, 2008 | 11:15 PM
Kevno6's Avatar
Kevno6
Is this what is needed.
http://cgi.ebay.com/ebaymotors/2002-...spagenameZWDVW
Old Jul 31, 2008 | 12:44 AM
Pyro's Avatar
Pyro
I Beat Tetris
The PCM is on the firewall on the passenger side. It's pretty easy to remove and replace, only 3 screws.
Old Jul 31, 2008 | 11:25 AM
Bullcrappy's Avatar
Bullcrappy
if you got a programmer try flashing it....
gl
r
Old Aug 1, 2008 | 12:30 AM
Kevno6's Avatar
Kevno6
Already tried will not work. I am probaly going to order PCM from company. Talk to them today and they told me the code that I was getting even before I told them. They sound reputable and feedback is good. You just have to give them your Vin, Mileage and part #.
Old Aug 3, 2008 | 07:55 PM
Kevno6's Avatar
Kevno6
Ordered Pcm and it should be here tomorrow. $209 out the door 2 day shipping. All programmed for my truck.
