07 aftermarket radio install question
Old Jan 27, 2008 | 02:35 PM
neveuxpr's Avatar
neveuxpr
Default 07 aftermarket radio install question
I've read that the 07's have the 70.00 adapter needed to get a switched power supply. Does anyone know if an adapter for 06 will work if I run a separate switched power supply. Will the adapters for 06 and 07 be the same size? I'd much rather spend 5 bucks than 70 and run a few more wires.
Thanks!
P.S. Plain 4 speaker system w/o Infinity or steering wheel controls.
Old Jan 27, 2008 | 06:31 PM
brianas's Avatar
brianas
Default RE: 07 aftermarket radio install question
yes 06-07 ram 1500 are the same,
get the cheap harness and /l
tap your switched 12v+ off of the switched lighter outlet
unless your adding a in dash nav, then buy the adapter
it has vss and rev as well as the acc wire
g/l
