normal to jerk in 4 wheel when turning?
Old Jan 28, 2008 | 10:42 PM
RAM0447's Avatar
RAM0447
Default normal to jerk in 4 wheel when turning?
Hey guys, new to using the 4x4....anyway, is it normal for my truck to jerk when turning in 4 high? When I was driving in the snow, I did a couple sharp turns slowly and it like jerks and stops and goes. It does it everytime...so is that normal? Doesn't do that in reg. 2 wheel but hopefully that's what happens! Thanks
Old Jan 28, 2008 | 10:51 PM
ccdmader's Avatar
ccdmader
Default RE: normal to jerk in 4 wheel when turning?
Yes its completely normal. The inside tire rotates slower than the outside tire when turning causing the inside wheel to hop. Since the tires are locked together in 4X4 they have to turn the same speed, you will find if you have to turn really sharp you either have to take it out of 4X4 or use a littel throttel to make the front end slide a little. Never engage 4X4 unless its slippery as this can cause serious drive train damage.
Chris
Old Jan 28, 2008 | 10:54 PM
RAM0447's Avatar
RAM0447
Thanks a lot bro! Yeah, only time I have used mine is in the snow or when the roads are covered with light snow/ice. I was just curious!
Old Feb 15, 2008 | 03:33 PM
dwoods's Avatar
dwoods
yea u better not use it on plain concrete eithercause if ur not really careful u can tear up ur transfer case
