Ok, Im going to ask.....
Old Jan 29, 2008 | 01:18 PM
beerformeplz's Avatar
beerformeplz
Default Ok, Im going to ask.....
Ive tried the search feature and it didnt return what I was looking for so here goes.
I have an 07 Ram 1500 QC 4x4 with the front leveling kit and I have some tax refund money burning a whole in my pocket so its time for rims and tires. I was looking at this http://cgi.ebay.com/ebaymotors/17-BL...QQcmdZViewItembut im not sure on which tire size will fit along with which off set for the rim. I think I read that 35s will fit with the leveling kit but after talking to the people at the company selling them they said there no way 35s will fit.
Any help would be awsome.
Old Jan 29, 2008 | 01:30 PM
kregier's Avatar
kregier
Default RE: Ok, Im going to ask.....
Someone else should chime in eventually, but I'm pretty sure 35s will fit but you'll probably get some rubbing if you crank the wheel completely in either direction and they'll probably rub if you hit a bump that would normally bottom out your suspenstion.
Old Feb 9, 2008 | 07:45 PM
beerformeplz
no more advise?
Old Feb 9, 2008 | 07:57 PM
TANKZ400's Avatar
TANKZ400
35 inch tires will fit with a leveling kit
Old Feb 9, 2008 | 08:46 PM
mmstar23's Avatar
mmstar23
as far as my knowledge is, and what ive learned, 35 should fit. you may have a little rub, but if you do, you can crank your torsion bar to give you a the extra clearance you need
