Anti-sway bars?
Old Feb 22, 2008 | 05:59 PM
oefootball_70's Avatar
oefootball_70
Default RE: Anti-sway bars?
I wonder if I could still do it with my lift?
Old Feb 22, 2008 | 06:03 PM
masshole's Avatar
masshole
No drilling, just simple mechanic wrenches... The directions are crappy as all hell, but it went rather quick considering I was freezing my butt off!!!
I also installed a Hellwig, so I don't know if any other set-up requires drilling!
Old Feb 22, 2008 | 06:09 PM
masshole's Avatar
masshole
Installing a Anti-Sway bar with a lift on the truck I'm not quite sure about that one. I do know if you go off-road a lot, you lose articulation in the suspension. But, if you are like me I don't do that much to worry about it. Now that I have this sway-bar, I can't see driving a truck without it at all; a must have. Cornering and handling greatly improved..
Old Feb 22, 2008 | 10:20 PM
buganddoug's Avatar
buganddoug
How about a part number?
Old Feb 24, 2008 | 12:20 PM
stratusguy02's Avatar
stratusguy02
How about on road ride quality? Does it ride stiffer with the swaybar?
Old Feb 27, 2008 | 11:41 PM
HemiLonestar's Avatar
HemiLonestar
I had to take mine out foe dual exhaust, has anyone found one that will clear the factory dual kit (Borla)?
Old Feb 28, 2008 | 07:18 AM
MikeHTally's Avatar
MikeHTally
As far as I can tell, the sway bar has not affected ride quality. Some sway bar kits require drilling, but not the Hellwig. When I had my Magnaflows installed, they had to custom-fab some pipes to clear the shocks and the sway-bar.I'd say the Hellwig was the best "performance" mod I've done to my truck.
Old Feb 28, 2008 | 09:20 AM
2005cobrakiller's Avatar
2005cobrakiller
if your exhaust is in the way re-route...most people are scared of it...but exhaust pipes are easy to re-route cut em and re weld em.....
Old Feb 28, 2008 | 07:26 PM
kenihemi's Avatar
kenihemi
What he^^^^^ said.
Old Feb 28, 2008 | 07:42 PM
masshole's Avatar
masshole
Just be sure to check out everything, after 500 miles. Re-torque per manafacture specs and adjust if needed. I just checked everything out today and everything was fine.
So far, I'm loving this mod, by far the best thing I did!
And if anybody has any questions, just ask me or PM me! I know some are having trouble around the resonator. I managed 1" clearance along side the resonator and maintained factory specs. Also, I have 1" clearance along side the spare tire.
