'06 RAM HEMI...WON'T SHUT OFF....HELP!
Old Feb 3, 2008 | 05:06 PM
Dran_Dragor's Avatar
Dran_Dragor
Default '06 RAM HEMI...WON'T SHUT OFF....HELP!
Hi!
I have a '06 Ram Hemi 4x4 with 13,000 km's on it. I have had no trouble at all with it. Today I drove to the mall and when I turned the key off and pulled it out I realized the radio was still on. I then realized that the truck with still running. All the guages go off when I shut the key off. If I cycle the key back to the run position they all turn back on and the truck seems to run fine....Although the motor never shuts off.
I eventually took the key out and pissed around under the hood seeing if some water got into the fuse box or something...>Everything seems ok. THe truck then died out. I then was able to start it up again using the key, however now there is a check engine lite. I read the codes and I pulled a P0700 code. I believe that is a transmission code...I have no idea how this problem would pop a transmission code but anyhow it did. I can now turn the truck on and off normally.
Has anyone else had something like this happen to them?
Cheers!
Old Feb 3, 2008 | 05:07 PM
JD1500's Avatar
JD1500
Default RE: '06 RAM HEMI...WON'T SHUT OFF....HELP!
Man, that is crazy. I would just take it too the shop. Ive never heard of this...
Old Feb 3, 2008 | 08:45 PM
TANKZ400's Avatar
TANKZ400
That's pretty funny maybe you should quit pissing it off.
Old Feb 3, 2008 | 10:12 PM
Dodgethis07's Avatar
Dodgethis07
Can some one please help me I dont know what to do with my 07 Dodge 1500
Old Feb 3, 2008 | 10:37 PM
JD1500's Avatar
JD1500
No one else does either, that is why you have a bunch of views and only reply to take it too a shop.
Old Feb 3, 2008 | 10:42 PM
CarGuyOhio's Avatar
CarGuyOhio
I would not even try to wager a guess given it is under warranty. Warranty work is the best service, free!!
Old Feb 3, 2008 | 11:53 PM
Hemiroid's Avatar
Hemiroid
i had a 1988 Chevy Caprice Classic which wouldnt shut off, could be something as simple as timing, as for the caprice i never found out the cause because it was stolen from right under my bedroom window.
Old Feb 6, 2008 | 12:53 PM
hollywood703's Avatar
hollywood703
if it is a transmission code, maybe the tranny is in between gears for some reason......it may not allow it to shut off, but that would be rare, I do not know what that code is, but i would agree, call or take it to the shop if it is still under warranty.
Old Feb 6, 2008 | 12:59 PM
Parts/Service's Avatar
Parts/Service
The p0700 code in the powertrain control module is there to tell you that there is a code in the transmission control module (TCM). You need to have the TCM codes read and see if that sheds some light......
