gear ratio???
Old Feb 11, 2008 | 02:09 PM
caliboy@heart's Avatar
caliboy@heart
Default gear ratio???
I have an 04 QC 4x4 hemi and it has the off road pkg. it came with the 3.92 axle as opposed to the 4.10............so what does this mean. I assume it means that i have lower gears for "off roading" where the 4.10 is geared for the highway. Please give me some info. Thanks!
Old Feb 11, 2008 | 02:21 PM
JD1500's Avatar
JD1500
Default RE: gear ratio???
It's the other way around man. Higher numerical numbers=lower gear. 3.92 is the most common all around gear. 3.55 is the Higway, dont tow ger ratio.
Old Feb 11, 2008 | 02:33 PM
caliboy@heart
so do some of the 3rd gen rams come with 4.10? Or am i just wrong?
Old Feb 11, 2008 | 02:47 PM
JD1500's Avatar
JD1500
not sure about the 1500's but you can get the 3/4 and 1 ton's with the 4.10's. 4.10's and 4.56" are the most common gear change on the 1500s for guys that tow, or have big tires, or both.
I am switching to 4.10s when i put my trutrac in.
Old Feb 11, 2008 | 02:50 PM
caliboy@heart
ORIGINAL: JD1500
in the next year or two i may have to tow 1-2 vehicles anywhere from a few hundred miles to cross country. is it worth it change gears or can i get by with the gears i have now. what would be the benifits of getting the 3.96 changed out for the 4.10?
Old Feb 11, 2008 | 03:01 PM
chongo's Avatar
chongo
none really - for the amount of money you will spend in the gear swap going from 3.92 -4.10 would not be worth it IMO - if you are wanting more gear go to 4.56, you will get your moneys worth then.
If you are happy with what you have now then keep what you have - if you are only going to be towing something once or twice in a year then there is really no point. Are you going bigger in the tire dept? If you are going to go to bigger tires then yes I would regear, but for what you described, personally I would keep the 3.92.
Old Feb 11, 2008 | 03:06 PM
JD1500's Avatar
JD1500
yeah, swapping gears is a expensive undertaking for a 4x4. 1000-1400 installed. For towing there is nothing wrong with your 3.92's it wouldnt be worth the expense.
Old Feb 11, 2008 | 03:43 PM
caliboy@heart
I may go bigger tires in the future with a lift kit, maybe a 4-6 inch. would i really need the gear change then. what would i feel in the truck if i keep the gears at 3.92 and got the lift with bigger tires?
Old Feb 11, 2008 | 05:12 PM
JD1500's Avatar
JD1500
well, it depends on the size of rubber your going with. if your gonna run 35's, and tow everyonce in a while you will be fine with your stockers. If you wanna go bigger like 37's, or you want 35's and are gonna tow quite a bit, or want to keep you mileage you should probably run 4.56's but a 37" tire or above you will need gears.
Old Feb 11, 2008 | 05:24 PM
oefootball_70's Avatar
oefootball_70
if you keep the 3.92 gears and the bigger tires you will feel sluggish.
