Amplifier Installation
Old Feb 21, 2008 | 02:19 PM
melhoff13's Avatar
melhoff13
Default RE: Amplifier Installation
I see now. Cool...Looks easy enough....How many bolts did you have to put the washers on....I have not taken the seat off so I'm not sure how many bolts I need.
Old Feb 21, 2008 | 02:23 PM
StevenMoffettKY's Avatar
StevenMoffettKY
It was very easy. 4 bolts. and I used 51 washers on each bolt, giving me about a 4" lift. You might not need as much, I could've gotten by with 2-3", but unfortunately Lowe's didn't have enough of those sized bolts, so my hand was kind of forced since I'm impatient. Good luck!
Old Feb 21, 2008 | 02:30 PM
melhoff13's Avatar
melhoff13
Thanks for responding on this. Now I should be able to get this taken care of! Thanks!
Old Feb 22, 2008 | 10:45 AM
melhoff13's Avatar
melhoff13
I plan on doing this install tomorrow so hopefully this seat raising thing will work. Hopefully, I can get the amp hooked up to the stock HU without having to mess with the stock amp...I have a LOC and the amp has a built in LOC, so I'm gonna tap into the rear speakers and give it a go...should work...but you never know!
Old Feb 24, 2008 | 03:27 PM
melhoff13's Avatar
melhoff13
Got it in. I'm having some power issues with the battery, but everything is a go. I ended up using the wiring harness that came with the amp instead of wiring the LOC and using the RCA cables. Everything is good. Sound is great. Now I just have to figure out how to get the darn battery gauge to stop fluctuating....Thanks for all the help!
Old Feb 25, 2008 | 07:11 PM
melhoff13's Avatar
melhoff13
WOW
Old Feb 25, 2008 | 08:11 PM
melhoff13's Avatar
melhoff13
I put picks up in my gallery if anyone is interested. I had to crop them down some but you can see most of the install.
