my motor blew !!!!!!!!!!!!!help!
Old 02-28-2008, 12:11 PM
turbot_bird's Avatar
turbot_bird
turbot_bird is offline
Default RE: my motor blew !!!!!!!!!!!!!help!
ORIGINAL: derricksmash
that blows ***.
that hole in your block (if i think it's what it is) is supposed to do what it did. piston froze up, and instead of letting compression explode through your engine and ****, it blows out a cap in the block.
[/img]http://www.carsask.com/media/Coolant%20Drain%20and%20Refill/block%20drain.JPG[/img]
^^ in this photo, you see that silver/gray plug above the block drain? is the hole that blew out...like a gaping hole? or is a perfect circle?
No, in his pic you can see the freeze plug then the hole next to it. The second hole is not the freeze plug. They are used for when the coolant freezes in the block it doesent crack the block it pushes the plugs out and releves the pressure.
  #22
Old 02-28-2008, 12:23 PM
petes4x4hemi's Avatar
petes4x4hemi
petes4x4hemi is offline
the heck with it find yourself a 426 hemi and show those tundra's what your truck is really made of .
  #23
Old 02-28-2008, 12:31 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
Looks more like a thrown rod to me
  #24
Old 02-28-2008, 01:35 PM
abarmby's Avatar
abarmby
abarmby is offline
Holy ***t dude...............that's a big hole!!
Hope ya get fixed up bud?
Al.
  #25
Old 02-28-2008, 01:40 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
A little duct tape on the hole should fix you right up.[&:]
Seriously, your 04 has the 7/70 Powertrain Warranty. They may give you a hard time about your mods, but hold your ground, the burdon of proof is on them if they claim any mod caused the problem.
I had a '98 Ford F-150 4x4 and a piston cracked with only 14K on it while towing my bass boat home from a tourney at Lake Sinclair to my home (at the time) in south Ga.
I fought the dealer for over a week as they said my cat-back exhaust voided my warranty. After getting nowhere with them, I had a lawyer write a letter (that's when I learned about the Magunson-Moss Act as the lawyer explained it to me). The same day they were in receipt of the letter, the service mgr. called me and apologized for the mis-understanding and tried to say I mis-heard him (yea, mis-heard the words "NOT COVERED" over a half dozen arguments with him!!!) and from then on there was no question that it was a warranty repair.
BTW - Traded that POS Ford in on a new '98 Dodge RCSB 4x4 w/5.9 the day after I got it back. I'll never own a Ford again.
Anyway, just stick to your guns. Good Luck...
  #26
Old 02-28-2008, 02:20 PM
chadrules's Avatar
chadrules
chadrules is offline
ORIGINAL: HammerZ71
thus he still blames you and is an a-h0Le
  #27
Old 02-28-2008, 05:43 PM
TANKZ400's Avatar
TANKZ400
TANKZ400 is offline
http://www.pt-tuning.com/policies/Magn-Moss-Act.html
Here you go give them hell they have to fix it under warranty unless they can prove it take your programmer out and set it back to stock before you go in there.
  #28
Old 02-28-2008, 06:01 PM
killerbud420's Avatar
killerbud420
killerbud420 is offline
yea some duct tape lol if you cant duck it fuc* it i try to get some better pics i got like a 20 camera so...but i went to where i blew it up at an found whats looks to be the part of the cylinder wall brother givin me hell about it he's a Chevy person
  #29
Old 02-28-2008, 07:06 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
Did you raise the rev limiter?
  #30
Old 03-01-2008, 07:57 PM
killerbud420
yea hey i put my stock air hat on it why i was in there i push the t/b open an there was alot of water some oil an metle an some kind of yellow **** all over the place i know thats normal whats that from?
Quick Reply: my motor blew !!!!!!!!!!!!!help!
