LIFTING MY 2002 RAM 1500
I went with the 5.5" Superlift. It's a bit on the pricey side but well worth it as it is very rigid and comes with a built in front differential skid plate. Now i run 35" x 12.5" MT FC2's. The truck is very stable over all. But i feel it's important to go with a wider tire along with the lift to offset raising the center of gravity. If you do go with a wider tire you'll need aftermarket wheels as well to avoid rubbing on the inside.
