codes
Old Mar 10, 2008 | 07:27 PM
millerwildcat1's Avatar
millerwildcat1
Default codes
hi everyone.I ran the code test and these codes came up. c code aa00 ab00 ac00 ad00 and 0000. Can anyone tell me what these mean? Thanks
Old Mar 10, 2008 | 08:52 PM
chadmech28's Avatar
chadmech28
Default RE: codes
these are unrecignized codes this means the module is bad. Replace it
Old Mar 11, 2008 | 04:11 PM
millerwildcat1
Default RE: codes
Hi! thanks! But by module, do you mean instrument cluster?
Old Mar 11, 2008 | 08:45 PM
kenihemi's Avatar
kenihemi
Default RE: codes
Those are "C" codes, you must have an 04 and did the key trick to get them, right?
They don't mean squat.
Forget about chad's post.
You need to have a code reader put on your truck and get the "P" codes, then post them.
Old Mar 11, 2008 | 10:07 PM
chadmech28's Avatar
chadmech28
Default RE: codes
poooo means internal fault in the controller, this is a real code and it means the module is screwed!
Old Mar 12, 2008 | 05:16 PM
millerwildcat1
Default RE: codes
hi, my truck is a 05 with 33,854 miles on it when the odometer stopped working. By module, do you mean instrument cluster? My speedometer, odometer, brake lights, turn signals, wipers,and horn do not work either. none of my gages work and the instrument panel is lit up like a christmas tree. any ideas? truck still runs great.
Old Mar 12, 2008 | 06:31 PM
chadmech28's Avatar
chadmech28
Default RE: codes
How are you getting this code? Did you do a battery disconnect? if not do it. Next check the abs connector to see if there is water in it, this can cause very strange things to happen. You will want to get a drb 3 on it to diag this correctly, It sounds like you have a bad MIC (mechanical instrument cluster)! I hope this helps. Also check all of the fuses in the pdc.
Old Mar 12, 2008 | 07:00 PM
kenihemi's Avatar
kenihemi
Default RE: codes
Uh, he didn't say P0000, he said 0000.
0000 means no more codes C codes.
The kind you get when you do the key trick in an 04.
Old Mar 13, 2008 | 04:29 PM
millerwildcat1
Default RE: codes
hi, i did the battery disconect and thats how i got the codes. already took it to the dealer and they said its the wiring harness and asked me 900.00 plus labor to change it out. he said that if you shake the harness it works. but if i hit a hard bump it might knock them out again. so i'm kinda stuck. any ideas? thanks
Old Mar 13, 2008 | 07:34 PM
chadmech28's Avatar
chadmech28
Default RE: codes
what wiring harness did they say yo need?
