DIY bed liner
Old Mar 11, 2008 | 04:19 PM
cddailey's Avatar
cddailey
Default DIY bed liner
Has anyone done the DIY bedliner themselves? If you dont know what im talking about its the kit you get in a box and its like a spray on bedliner but you basically paint it on yourself. I just didnt know if anyone has tried it and seen if it was easy or not.
Old Mar 11, 2008 | 04:25 PM
The Peddler's Avatar
The Peddler
Default RE: DIY bed liner
A friend of mine done the herculiner, and it looked as good as rino or line-x, but he really spent alot of time on the prep work. I have been told that the prep work is where the trick is in making it a good or bad bedliner.
Old Mar 11, 2008 | 04:40 PM
cddailey's Avatar
cddailey
hmmm...what kind of prep work...and do you know how long approx it took him to do the whole thing? I was thinking you could just starting going away at it.
Old Mar 11, 2008 | 04:41 PM
red06RAM's Avatar
red06RAM
You have to clean the bed, sand the whole surface, wipe with acetone, then apply at least two coats. I don't know how strong it is but it is much cheaper than a sprayed on liner. I beleive you can get the Herculiner kit for under $100.
Old Mar 11, 2008 | 04:58 PM
ride_002000's Avatar
ride_002000
I used the Duplicolor roll on bed liner and it took awhile to do but looked good for a little while and then it started to chip and come up. But I think if you put 3-4 coats on it will hold up better.
Old Mar 11, 2008 | 05:00 PM
cddailey's Avatar
cddailey
so it sounds like the spray-on works better and is easier and lasts longer
Old Mar 11, 2008 | 05:53 PM
The Peddler
The friend of mine has had it about 5 years, and he is hard on it, and it looks just as good as it did the day he do it. I know you have got to clean the bed really well and sand all the paint before you put the bedliner on. Just got off the phone with him and he said it took him about 3 hours to get the bed ready, about 1 hour to roll the liner on. Then the next day he put a second coat on, and did not use the bed for another 4 days. He also said to do this in the hot part of summer.
Old Mar 11, 2008 | 05:55 PM
Timmerduder's Avatar
Timmerduder
I just got a quote on the over the edge Rhino for $479 complete. I had the Linex in my old truck, was definately tougher but was scratched up as well.... The Linex stuff slides around and the Rhino is more rubberier
Old Mar 11, 2008 | 06:02 PM
cddailey's Avatar
cddailey
well its gonna be very seldom that i use it i just dont want the bed to rust is all.
Old Mar 11, 2008 | 06:43 PM
ride_002000
Could try a tonneau cover to stop rain from getting in so it wont rust. And if done right like Peddler says it probably could last, but when I did it I was in a hurry and didnt prep like his friend did.
