NEED HELP NOW!!!!!!
Old Mar 13, 2008 | 04:50 PM
herring_jerritt's Avatar
herring_jerritt
Default NEED HELP NOW!!!!!!
I cleand my TB and PCV vaulve today and i took it around the block and it worked great but the check engin light came on and i dont know y!
Old Mar 13, 2008 | 05:02 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
Default RE: NEED HELP NOW!!!!!!
buy a new valve. u prolly broke'd it.
Old Mar 13, 2008 | 05:08 PM
Gone Fishin's Avatar
Gone Fishin
You might want to reset the ECM. I did mine a while back, and I read somewhere, maybe the FSM that the computer has to reset the TB. The way I'd suggest doing this is to disconnect the battery, turn on the headlights for about 10 seconds to denergize all electricty that may be present. Then reconnect battery.
Turn the key on to the run position without starting it. The computer will go throught the initial diagnostics, and reset the TB. If this doesn't take care of it, you'll get codes that will need to be addressed.
I'm assuming that you have a 5.7 from your sig. If you forced the butterfly in the throat of the TB, you may have bigger problems yet. Also, it is recommended that you use brake cleaner to clean the TB. It has very delicate sensors necessary for "Throttle by Wire to operate"
Good Luck, post back if it doesn't clear up
Old Mar 13, 2008 | 08:41 PM
RamItOne's Avatar
RamItOne
when you took off the plenum did you disconnect the mass air sensor?
disc the batt for about an hour (tried 20 min before and that didnt work) and the light should go away, that or about 1 inch of electrical tape and youll never see the light again.
Old Mar 13, 2008 | 08:43 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Post the DTC P code...autozone will let you use their scanner for free.
Old Mar 13, 2008 | 08:46 PM
HammerZ71's Avatar
HammerZ71
A lot of people either bump the air sensor or get crud on it while cleaning the TB. That is whereI would start...
Old Mar 14, 2008 | 12:10 AM
herring_jerritt
it drove it in to town to go to auto zone and on the way therethe check engin light just turned off, and it hasnt come back on yet so i hope thats a good thing!
Old Mar 14, 2008 | 12:23 AM
mmstar23's Avatar
mmstar23
my truck does the same thing. ill have a problem...let it go for a day or 2 (as long as i know its not major) and if its not better then i drive it to this guy i know who runs a diagnostic on it for free...and its been twice now that ive had a problem and on the way to fixing it, it fixes itself...weird truck man....has a mind of it own haha...almost as if it wants attention lol. atleast it fixes itself though
