2x4 lift
Old Mar 21, 2008 | 07:44 PM
Max1775's Avatar
Max1775
Default RE: 2x4 lift
I have done a lot of suspensions in my time and I never used them before, but I tried every trick I know and couldn't get the spring and spacer in. The compressors should make it cake. I will post when I finish.
Old Mar 21, 2008 | 07:52 PM
damram1980's Avatar
damram1980
nice to talk to a fellow constuction worker. why'd u buy a 2x4............4x2[:-]
Old Mar 30, 2008 | 08:45 PM
Max1775's Avatar
Max1775
Switching jobs and just got a great deal on this one. I hope to replace it in a couple of years with a 4x... I really like the truck though.
Old Mar 30, 2008 | 09:29 PM
Avenger2NV's Avatar
Avenger2NV
I have both 3" lift spindles and 2.5" lift coils... I was told "If you have to raise the front of your truck go with anything BUT spacers" This was from a mechanic i've known for years and had done several lifts.
Old Mar 31, 2008 | 09:06 AM
RaptorRacing's Avatar
RaptorRacing
There are a few options depending on the money you wnat to spend but always remember the you pay for quality i went with the spindles for a gew reasons ... spindles give you the most bang for your buck the ride quality doesnt change and they r made to last, As for new coil springs you are looking at a ruffer ride from, what i have heard and the dreaded coipl spring spacer ( i have heard Horror stories) they are cheap easy to install , but i have had friends install them and had them pop out , i even had a friend the the material started to dry rot???? just what i have heard but my opinoin is the spindles is the safest and best way to go more money but once again you are getting what you pay for...
Old Mar 31, 2008 | 10:19 PM
2007 st's Avatar
2007 st
I DID NOT USE A SPRING COMPRESSOR ON MY INSTALL, OF COURSE I ONLY PUT IN 1.5 SPACERS. I WOULD NOT SAY IT WAS EASY... BUT I GOT THEM IN THERE.
Old Mar 31, 2008 | 10:20 PM
2007 st's Avatar
2007 st
DO YOUR SELF A FAVOR, IF ANYONE WANTS MORE THAN 2 IN LIFT GO WITH THE SPINDLES. WILL RIDE BETTER
Old Apr 1, 2008 | 08:43 PM
Max1775's Avatar
Max1775
After reading all the replies, I think I'll run the 2" spacers until I can go with 3" spindles. Thanks for all the help!
Old Apr 1, 2008 | 09:26 PM
2007 st's Avatar
2007 st
good choice
Old Apr 2, 2008 | 11:32 PM
roadney's Avatar
roadney
I just ordered the 2.5" spacers. hope to get them in this weekend. I also hope it doesn't screw up my front end.
