2x4 lift
Old Mar 13, 2008 | 09:57 PM
Max1775's Avatar
Max1775
Default 2x4 lift
So what is everyones solution for lifting the front end of a 2x? Spacers, springs, spindles? Pros and cons? Let's hear it![sm=feedback.gif]
Old Mar 13, 2008 | 10:00 PM
JD1500's Avatar
JD1500
Default RE: 2x4 lift
Well...It's 4x2 first of all, this isnt the lumber yard
Do some searching and youll find a bit of info.
I am all for it, i think it looks cool. and if your somewhere you dont need 4x4 but like the look, why not. No different than the huge 4x4 that are just pavement queens. A lift is going to be a little harder to track down. but lots of people have done it. I think the spindle lift was the most popular.
I say just level it out and slap some 35's or 36's on it.
Old Mar 13, 2008 | 10:10 PM
Max1775's Avatar
Max1775
Lol.. 2x4, too many years in construction I guess... I've been searching, looking and everything else, just doesn't seem to be a lot out there. This is the first 2wd truck I've had in many years, and I just want to raise the front a little to keep in from sagging so much. I already put a set of ride rite bags on the back to keep it from squatting under a load...
Old Mar 13, 2008 | 10:11 PM
mmstar23's Avatar
mmstar23
hey ive been looking too and the best thing ive found are the polyurethane spacers made by daystar. i plan on buying some tomorrow night. i have a 3" body lift and im gonna put the leveling kit on and thatll be it. and ya, this isnt a plank of wood here its 4x2 or simply 2WD
Old Mar 13, 2008 | 10:15 PM
Max1775's Avatar
Max1775
I bought a set of spacers, just waiting on the spring compresssors to come in. I just hope it is enough.
Old Mar 13, 2008 | 10:22 PM
mmstar23's Avatar
mmstar23
i dont think you need spring compressors, just use another jack and let it down slowly.
where did you get your spacers and for how much? and how tall are they?
Old Mar 13, 2008 | 10:48 PM
2007 st's Avatar
2007 st
max, put a floorjack under the front and jack it up to the level you like. take a measurment at the fender above the tire, before and then after.
if you like it over 2 in higher go with spindles. under 2 u can use spacers. imyself put in 1.5 daystar spacers from summitracing on my 07 2wd reg cab,about 55.00 shipped. after install it sat about 1.25 in higher in front. looks much better.. i think on a 2wd 2in would look best.
let me know if you have any ?
Old Mar 14, 2008 | 09:04 PM
HammerZ71's Avatar
HammerZ71
Spacers would be fine for leveling your 2 wheel drive truck.
Oh, yea and that's really a pet peeve of mine, too. If your search this forum, you'd find at least a couple of dozen times that I've written "You own a 4x2, a 2x4 is a piece of wood"...
Not as durable as spindles or new coils, but then again, if you were gonna push it hard off road, you'd probably not have a 4x2...
Old Mar 17, 2008 | 09:20 PM
Max1775's Avatar
Max1775
ORIGINAL: mmstar23
I picked up a a set of 2" Daystar bushings off of ebay for $59. I tried the jack set up, but even with every imaginable thing pulled loose, the spring would not go back in with the spacer. Compressors are here now though, so this weekend will get 'er done...
Old Mar 17, 2008 | 11:15 PM
mmstar23's Avatar
mmstar23
so i NEED a coil spring compressor?
