Torque convertor going out?
Old Mar 17, 2008 | 05:17 PM
05king's Avatar
05king
Default Torque convertor going out?
I have experienced this problem about 5 times now. Always happens when the truck is cold. Only on the first time accelarating and only when going forward (I usually alwasy back in when I park) Acts just like the e-brake is on or I have 5,000 rpm stall in it. Seems to be getting worse. Fluid is full, clean, truck has about 18k on it 5.7 hemi (I have owned since new) Exhaust and superchips programer in it with 35" toyo's. Just started doing this recently. I don't think the e-brake is hanging up really seems like the trans. I was unsure if it was going to move today. It's under warranty so I will take it in but like to be educated on it just in case. Are these trucks known for having any trany or torque conv. issues?
Old Mar 17, 2008 | 05:52 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Torque convertor going out?
there was some issues back in 02 and possibly 03 where the fluid in the T.C. would drain out and if you immediately put it in gear then the person would experience the same symptoms that you are describing...i had this issue on my 02...if you start the truck and let it idle for a min then put it in gear it should be fine (if thats the problem) but might as well take it in as long as its under warranty
Old Mar 17, 2008 | 06:22 PM
05king's Avatar
05king
Thanks I also forgot to mention its a 2006
Old Mar 17, 2008 | 06:49 PM
MikeHTally's Avatar
MikeHTally
Should definitely be covered under the power train warranty. My '01 would do this after it sat for several days.
Old Mar 17, 2008 | 07:10 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: 05king
Mine does this also on cold starts and when accelerating the first time. For me it's my clutch fan being fully locked after sitting all night....i've had other trucks do it too and for me it's normal. It unlocks as soon as I drive about a block or so.
Old Mar 18, 2008 | 08:32 AM
HankL's Avatar
HankL
go in and have your CVI (clutch volume indexes) checked
Old Mar 18, 2008 | 01:17 PM
2005cobrakiller's Avatar
2005cobrakiller
mine was doing it and now im buying a new tranny so.......get ur cvi pressures read do a diag on the tranny do it now before its too late trust me....all i have left is first gear......wait till the new one comes in ooooh lala
