Old Aug 10, 2015, 05:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
How to clean throttle body in a 4.7
Old Mar 24, 2008 | 12:26 AM
De pinga!'s Avatar
De pinga!
Default How to clean throttle body in a 4.7
Alright so i heard you can clean your throttle body and get better mileage but how do i do that? i ahve a box that says 4.7 magnum but how do i open it? and what are the exact procedures for ex. how do i take it out and what do i clean it with etc.. thanks everyone.. Oh and how do i post pistures on this?
Old Mar 24, 2008 | 12:35 AM
bpv's Avatar
bpv
Default RE: How to clean throttle body in a 4.7
Ha Ha Ha, your own post answered itself. Check out the related links below...
[sm=smiley14.gif]
Old Mar 24, 2008 | 12:38 AM
RamItOne's Avatar
RamItOne
well typing this on my iphone so not gonna get too detailed
disc the battery, take off the tube running from your air filter to your plenum (that big black box ontop of your engine), theyre connected with hose clamps, a few twists with a flathead and youre good. theres gonna be 1 or 2 bolts, mine only had one, on the right side of the plenum, unbolt that, theres a hose clamp connecting the plenum to the throttle body, its a slight bitch to get at, again a few twists and youre good. you may or may not have a mass air sensor on the rear left of the plenum, 02 didnt have em, i know 06 and up do, so dont know about the years in between. once you have your plenum off you can see your throttle body, you can either just clean what you can see with a microfiber cloth and some brake cleaner, or you can take the throttle boddy off, 8mm i think, itll be a lot dirtier on the side that you cant see while attached, i spray the hell out of mine, some people say ooooh dont get the inside too wet, F it its combustable. if you do take it apart youll need a new gasket. while youre doing that you may want to run some cleaner in your pcv valve (thats the lil 1 inch or so tube coming out of your air filter box) they sell cleaning kits for that, i think a lot of people like sea foam, ive never used it though. while youre at it, how many miles do you have on it? whens the last time you changed the plugs? you should use the same plugs as i do, RC12MCC4 gaps a 40, its a copper champion, dont let the moron at the counter tell you plat is better.
once every thing is back on and if you throw a code, just disc the batt again for 20-30 min and start it back up. dont forget to plug that mass air sensor back in.
Old Mar 24, 2008 | 09:25 AM
dwoods's Avatar
dwoods
ok now does it really help gas mileage?
Old Mar 24, 2008 | 01:28 PM
JD1500's Avatar
JD1500
It helps if your TB is dirty and your mileage has dropped. It gets crud in it from the egr system, witch makes it stick a little, and not flow air as well, wich makes your mileage drop.
Old Mar 24, 2008 | 02:07 PM
Redram05baby's Avatar
Redram05baby
It's Going To Return Your TB As It Was The Day It Pulled Off The Lot - It Will Help With Rough Idle Situations.
Old Mar 24, 2008 | 02:48 PM
damram1980's Avatar
damram1980
help rough idle? what about on a durango i think its the same motor 4.7?
Old Mar 24, 2008 | 07:08 PM
kx250frider617's Avatar
kx250frider617
I just cleaned mine on my hemi and right when i started it it idled like a 1964 POS. A minute later it was perfect. I recently lost some power but after i cleaned it I think i got it back. When doing it make sure you don't drop anything in the hole that goes into the engine, You'll be so screwed if you did that. I just did a few WOT passes and once the tranny down shifts it takes off so fast like you can really feel the G's.
Old Mar 24, 2008 | 08:02 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: RamItOne
You typed all that on your Iphone...good gawd man how long did that take?
Old Mar 25, 2008 | 01:17 AM
RamItOne's Avatar
RamItOne
I type fast, i dont remember what df'r i was talking to, he has the blackberry pear (phone i still have just dont use often any more) was telling him i bet i could type faster than him lol. im pretty sure i can type faster (my iphone vs their standard cpu keyboard) than a lot of guys that didnt grow up in the computer age. on a real keyboard i type 60ish per minute, my buddys a comp programmer, fvcker types in the 120's per min. thats just insane.
well hope it helped the guy that wanted to clean his TB
just replaced my plugs for the first time 31k, looked bad, not nasty but bad. my buddy replaced his for the FIRST F'ing time at 92k last week, took 2 hours cause everything was rusted and gunked on. those sons a bitches looked nasty...
