differential locker
Old Mar 25, 2008 | 08:28 AM
stratusguy02's Avatar
stratusguy02
Default differential locker
Does anyone run these?
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 25, 2008 | 11:21 AM
Horseapples's Avatar
Horseapples
Default RE: differential locker
I havent used this brand, but they sound good from the description. And Summit doesnt normally sell junk. I have never had an issue with quality from Summit. You can always research the company or contact Summits tech assist for further info. Are you planning a gear swap also?
Old Mar 25, 2008 | 11:24 AM
Horseapples
I just did a little research out of curiosity. These units are made by Richmond gear. I would bet on them being high quality units.
http://www.powertrax.com/
Old Mar 25, 2008 | 12:25 PM
Heminator2's Avatar
Heminator2
I don't see any for an 05 Hemi though.
Old Mar 25, 2008 | 12:39 PM
HammerZ71's Avatar
HammerZ71
I remember reading on another forum someone had bad problems with the Powertrax's on a 2wd Hemi. Can't remember who, or on what forum, but I remember they kept "locking up" on him driving on the open road and almost caused him an accident. Had a 2nd set warranteed in, and had the same problem.
When I get a chance, I'll do some searching and find out who/where it was...
Old Mar 28, 2008 | 08:02 AM
stratusguy02
https://dodgeforum.com/m_1239634/tm.htm
Nobody should buy these, it appears they suck real bad.
Old Mar 28, 2008 | 10:38 AM
djr04's Avatar
djr04
The auburn and the detroit truetrac seem to be the lsd's of choice. From what I understand, you might get a little more durability out of the truetrac, but it is also more expensive. Also, if I remember correctly, one is a bit more harsh and the other is more forgiving. They are also different designs (auburn is clutch packs?). As you can tell I'm basing this off of memory, so research them both and you should find one you like.
Old Mar 28, 2008 | 03:17 PM
sk425k's Avatar
sk425k
i would get a detroit trutrac..i have adetroit locker in my wrangler but for the rear an LSD would be better.. just my .02
http://www.4wheelparts.com/PDT263613.aspx
Old Mar 28, 2008 | 04:16 PM
Horseapples
ORIGINAL: Horseapples
Of corse, I could be wrong! The Auburn unit is pretty cheap, it would be a good buy.
http://moesperformance.com/index.php...88b2980fb6510e
Old Mar 28, 2008 | 10:47 PM
oefootball_70's Avatar
oefootball_70
would this work with my 4.56 gears. And how in depth of an Install would this be?
