transmissions in the new dodges
Old Mar 27, 2008 | 08:01 PM
GREENandSILVER95's Avatar
GREENandSILVER95
Default transmissions in the new dodges
how well do the transmissions hold up under alot of power
Old Mar 27, 2008 | 08:12 PM
StevenMoffettKY's Avatar
StevenMoffettKY
Default RE: transmissions in the new dodges
ORIGINAL: GREENandSILVER95
As-in while towing or after a lot of performance mods and being heavy-footed with it? I think I've heard suggestions for a tranny cooler for a little better longevity.
Old Mar 27, 2008 | 08:41 PM
JD1500's Avatar
JD1500
Towing is fine, under lots, ie boosted, power its real questionable.
Just make sure you tow in tow/haul and hot rod in o/d off.
The weak link in these tranny's is the 2nd prime gear, specifically downshifts to it under heavy load/power. The tow/haul and od off lock out this gear, so it's not an issue.
Old Mar 27, 2008 | 09:05 PM
GREENandSILVER95
going to build a 5.7 hemi and put it in a 95 dakota mabey making 500 horses and a good shot of gas think a built trans will hold up to that dont really know a whole lot abot the newer trucks
Old Mar 27, 2008 | 09:13 PM
HammerZ71's Avatar
HammerZ71
On forums that are more geared toward the Performance Shops and major gear heads, the consensus is that 320-340 RWHP or about 430-450 at the engine is the mark where stock trannies start to tear up in 1500 & 2500 series trucks. You can basically add about 90 HP or so to a stock Hemi truck before having to think major upgrade to the tranny.
When I add the Cam to my current mods I'm going to be well into that area and don't think I haven't given a lot of thought to the added expense of bringing the tranny up to spec...
Old Mar 27, 2008 | 09:19 PM
GREENandSILVER95
thanks just wanted to see even if i built one would it hold up
i know that a 4l60 in a f body with a good bit of power wont hold up know matter what even if its built
