Installing fog lights
Old Mar 28, 2008 | 09:08 PM
roadney's Avatar
roadney
Default Installing fog lights
I want to install some fog lights in my Ram. It currently has the plastic fillers. Has anyone done this? I was thinking I could cut out the filler enough to fit a pair in.
Old Mar 28, 2008 | 09:25 PM
SeMiGoD's Avatar
SeMiGoD
Default RE: Installing fog lights
Im not sure how but they pop out. Im assuming the filler looks like a grille and not a solid cover. Some trucks are pre wired for them. I had my dealership pop a set of the "mopar" hella lights in as my truck was pre wired for them.
Old Mar 28, 2008 | 09:37 PM
roadney's Avatar
roadney
So if it is prewired than there should be plugs behind the bumper?
Old Mar 28, 2008 | 09:41 PM
SeMiGoD's Avatar
SeMiGoD
Not sure how they wire in but id assume so. Are the plugs in your bumper more like small grilles or solid blocks?
http://cgi.ebay.com/ebaymotors/ws/eB...29379&rd=1
Old Mar 28, 2008 | 10:07 PM
6 hemi ram's Avatar
6 hemi ram
if the inserts are like mine, the horizontal grill style, they pop out frome the inside of the bumper. i was given a set of 55 watt-4" fog type lights that i installed in the hole mounted to the frame. illl try to get pics tomorow.ran some wires through the firewall hole ( 2nuts hold on from the inside) to a switch in the little popout rectanglelow and leftof the steering wheel
Old Mar 28, 2008 | 10:10 PM
roadney's Avatar
roadney
ya they are horizontal grills. I will check out the pictures, sounds like that is the best idea.
Old Mar 28, 2008 | 10:33 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Like the others said, the grill looking inserts pull out...I pulled mine out through the front though. Check under the driveside bumper support for the factory pre-wiring...you'll see a unused harness pointed straight down if you have it. If you do you can get the factory fogs, the kit comes with a new headlights switch that pushes in for the fogs... along with inserts, Y-harness, the lights and all screws. I dunno what year your truck is but moparforless on ebay has them http://stores.ebay.com/Mopar4Less_Ra...QQftidZ2QQtZkm
Old Mar 28, 2008 | 11:24 PM
mikey0302's Avatar
mikey0302
Thats what I did with mine, was buy the factory set with switch for about 100 bucks took me all but a 1/2 hour to install including the switch. I am pretty sure they are all wired for them. I am sureyou could install an aftermarket set but its easier to go Mopar. the grilles do pull out from the front there is a clip in the back that you release and it slides forwardif Iremember correctly itsbeen awhile,the instructions come with the set.
Old Mar 28, 2008 | 11:31 PM
oefootball_70's Avatar
oefootball_70
yup I did mine, but I have no pics up yet.
Old Mar 29, 2008 | 12:05 AM
bpv's Avatar
bpv
I've done this andposted some info and pictures in this thread:
https://dodgeforum.com/m_1226906/tm.htm
Only SLT models come prewired for the fog lights.
