rear door/window do not work
After I sound deadened my rear passenger door, I closed it. When I tried to open the door, nothing. I tried opening from the inside and out. I thought maybe I clicked the child safety, but even if I did; I should be able to open the door from the outside. The window will not work as well. The auto lock clicks/moves. Oh, I did check the driver's lock was on--it wasn't. I checked the door mechanism and it seems to move when the handle is pulled. Any suggestions for a fix or should I take it to the dealership. Warranty is still in effect.
Thanks so much.
Thanks so much.
Well.... to get this straight... you took apart the door to add sound defening materials? and now the door won't open? Maybe you should pull it apart and remove what you have addded... and see if that makes a difference.... But if you did sumthing and take it to the dealer to complain... I'm sure they won't fix it...Well.. under warranty anyways... but rather charge you for diagnosing the problem...
