air/fuel ratio gauge
Old Mar 31, 2008 | 03:14 AM
roadney's Avatar
roadney
Default air/fuel ratio gauge
Are air/fuel ratio gauges difficult to install? What is needed for the install? I am thinking about putting one in to watch it and see if I can pull some more mpg's.
Old Mar 31, 2008 | 11:43 AM
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
Default RE: air/fuel ratio gauge
+1...I have one from Autometer sitting in a gauge pod on my truck...but I have NO idea where to buy the correct wiring harness to set it up....Let me know how things go if you have any luck
Old Apr 1, 2008 | 12:50 PM
roadney's Avatar
roadney
what kind of connector of wire does it have? do you have any pictures of them?
Old Apr 1, 2008 | 12:55 PM
XxSilentHawk99xX
I actually need to buy the correct wiring harness from Autometer...so I'm not sure...but right now there are 4 wires...
Old Apr 2, 2008 | 12:48 AM
daytona1680's Avatar
daytona1680
do you have a wideband A/F or just a regular A/F gauge? Unless you have a wideband you wont know what your A/F really is...as for install you need to have another bung welded into your exhaust for the o2 sensor that supplies the gauge with the reading, wiring isnt hard just follow the instructions that come with it
Old Apr 4, 2008 | 01:15 PM
roadney's Avatar
roadney
I read somewhere that you can attach the wire to the signal wire coming off of the first 02 sensor or at the ECU where it plugs in.
Old Apr 4, 2008 | 01:28 PM
daytona1680
On the 3rd gen rams dodge changed the voltage of the o2 sensors to the PCM, they are low voltage now. The aftermarket gauges use the older higher voltage so they are not compatable, which is why you need their o2 sensor. What kind of A/F gauge do you have?
Old Apr 4, 2008 | 03:01 PM
roadney's Avatar
roadney
i Don't have one yet but I guess it is almost pointless unless you have a wideband o2 so i probably won't get one.
Old Apr 4, 2008 | 03:28 PM
daytona1680
Yea, its more of a "show" thing unless its a wideband, and the only time you need a wideband is if your doing engine mods.
Old Apr 7, 2008 | 02:23 PM
XxSilentHawk99xX
I have the Pro Comp, and I think its wideband...but im not sure
