Parking lights wont turn off!
Old Jan 3, 2020 | 11:29 PM
NHPDtruck's Avatar
NHPDtruck
Default Parking lights won’t go off
[QUOTE=04MOPAR;1248105]Yeah the delayed headlight off feature is actually a good one, I have used that lots of times, but my problem is totally different, the parking lights are on, and they just stay on till the battery dies, just enough to **** me off [:@]electrical problems suck
did you ever diagnose and fix the issue with parking lights staying on forever??
im having exact same problem on our patrol vehicle
Old Jan 4, 2020 | 08:18 AM
This thread is 12 years old, and the original poster hasn't been here for ten years. Don't expect an answer.
Old Jul 17, 2022 | 10:29 AM
Kohler101's Avatar
Kohler101
Default Re
Originally Posted by Gone Fishin
The first place you might check is the relays in the power dist. box under the hood. The white relays are lame at best. I've had problems with my wipers, and occassionally, the head lights don't turn on. I cycle them, and they turn on. The replacement relays are around $20 at Autozone. On mine, they're all the same, so you might check that, and just try switching them around to see if thatverifies the bad relay possibility.
i have a 06 dodge 1500 with 4.7 liter and every viedo I watch all dodge talk places dont have anything for 06 with 4.7 im haveing same issue but only my pasenger side marker lights are ataying on
Old Jul 17, 2022 | 01:15 PM
Alex Medeiros's Avatar
Alex Medeiros
Do you have any LED or other lights that aren't Halogen bulbs?
Old Sep 20, 2023 | 07:25 PM
Goat420's Avatar
Goat420
New Member
Default Brake lights
Originally Posted by dbmowersports
It's funny you mentioned this,
I was on here looking for this very same issue, but on an '06 Caravan. Like Steven says, I just turn it back to on, cycle the lights, and they go out. It doesn't do it all the time either.Itseems to do it more when it's damp outside. I looked, and noticed I have a cracked headlight lens. You can see condensation on the inside of thelens. Maybe there is some corrosion in the headlight or something.
Jason
you need to pull up on your brake it’s stuck . U need to lube the pin in brake pedal . Just pull up on it nd your good but make sure you lube pin to avoid getting stranded
