braking shimmy mystery
My truck is an '06 4x4 and it was a salvage title front end damage. not enough to deploy the airbags. and the frame is straight as an arrow to my knolage.
OK so when I apply the brake I get a vibration.
I do NOT feel it in the brake pedal.
I do NOT feel it in the Steering Wheel.
I does seem to come and go a little.
I have had the rotors tuned and that did not help.
The tire Rods are new with only 2k miles on it.
This may sound wierd but if I am braking on slighly rough terain (like your average old pothole filled in road) I swear the vibration goes away.
It only seems to be there when I brake on smooth even road.
Any ideas where I should start to look? I'm planing on putting a leveling kit on it here in a couple of weeks so that would be a good time.
RE: braking shimmy mystery
Here is the recall. I drove an 06 that did not have it performed, it was bad.
https://dodgeforum.com/recalls-and-t...582/Recall.htm
ORIGINAL: RamWood
makes since, you cant feel the vibration because youre feeling the bumpy roads vibration.
Trending Topics
Not sure that this will help, but.....
TSB NUMBER: 22-005-06
SUBJECT:
Front End Shimmy On 4x4 Vehicles When Traveling Over Rough Surfaces In The Road
OVERVIEW:
This bulletin involves verifying the condition of the vehicle front suspension and steering
components, and adjusting the front tire pressure.
MODELS:
2003 - 2007 (DR/DH/D1/DC) Ram Truck (2500/3500)
NOTE: This bulletin applies to four wheel drive (4x4) 2500 and 3500 model vehicles.
SYMPTOM/CONDITION:
The customer may experience a self sustaining vibration (shimmy) felt in the front end of
the vehicle after striking a bump or pothole.
DIAGNOSIS:
If the customer experiences the above condition perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
(AR) 1 52106909AE Damper, Steering
(AR) 1 05086146AC End Package, Tie Rod Outer
(AR) 1 05086144AC End Package, Tie Rod and Link Outer
(AR) 06505623AA Nut and Washer, Tie Rod
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
