Changing Plugs
Old Apr 4, 2008 | 11:53 PM
RamItOne's Avatar
RamItOne
Default RE: Changing Plugs
i made this as a joke for redram after he installed a light for his hood.
sadly this actually has worked out well for me. i do have the factory hood light, but this is much better, and ive cleaned my tb at night before so the batt is disc.
[IMG]local://upfiles/80693/F963221A7BE54E83BF001906FEED66C8.jpg[/IMG]
[IMG]local://upfiles/80693/FC3F1DD829924EBB9D059023D8D1C011.jpg[/IMG]
Old Apr 5, 2008 | 09:12 AM
Horseapples's Avatar
Horseapples
ORIGINAL: RamItOne
someone on this site swears theres no reason for the swivel and that he has no issues changing the plug. I wonder if hes really changed em.
Plus 1 on the pad.
I am the one who does'nt use the swivel socket, and yes, I change them. I run a nasty shot of Nitrous at the track so plug life is somewhat abreviated, and I run colder plugs than stock.
All i do is drop the socket into the plug tunnel, insert a 3 inch extension, then attach the ratchet. I attack the drivers side from the intake side as to avoid the brake booster. On the passenger side I remove the EGR tube(2 8mm bolts)from the valve and remove the tube and clip from intake manifold, it only takes a second and the gasket is reuseable as long as its not damaged in removal. I'll add a pic of my engine Ramit so you wont think I am full of ****.
