fog lights
Old Apr 5, 2008 | 07:20 PM
05redhemi's Avatar
05redhemi
Default fog lights
hey guys i just ordered a set of fog lights off ebay and was wondering if any one had a simple set of instructions or pictures for wiring/set up????
anything will do
Old Apr 5, 2008 | 07:28 PM
RaiderJay6's Avatar
RaiderJay6
Default RE: fog lights
Did you order the Mopar ones? If so you might have a plug under the truck on the front where you plug it into.
Old Apr 5, 2008 | 07:58 PM
05redhemi's Avatar
05redhemi
unfortunatly no i got these things
http://cgi.ebay.com/ebaymotors/7-COL...spagenameZWDVW
btw my dodge cam stock without fog lights....
Old Apr 5, 2008 | 08:09 PM
2005DodgeRamDad's Avatar
2005DodgeRamDad
I am bidding on a set of factory foglights because it includes the factory light switch that is different than the one that my non-fog light Ram has. The difference is that the light switch you will need with the factory lights not only turns left and right, it also pulls out towards you... that is what turns the fog light on. The kit also has the bezels needed to mount the lights. It is more expensive but from what I have been told, much easier and complete. Here's an example:
http://cgi.ebay.com/ebaymotors/2003-...spagenameZWDVW
Old Apr 5, 2008 | 08:19 PM
05redhemi's Avatar
05redhemi
ive been told its easier but ive already bought these and there on there way i was more less just worried about wheres the best spot to put the wiring through the fire wall and where is best to draw the power from
Old Apr 5, 2008 | 08:32 PM
RaiderJay6's Avatar
RaiderJay6
Run the wires throught the rubber grommet for the throttle cable.
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: 05redhemi
anything will do
Your truck is more then likely pre-wired for the factory foglights...even though you don't have the actual lights. Look under the driverside around the front bumper support.
Old Apr 5, 2008 | 08:39 PM
05redhemi's Avatar
05redhemi
yea i do have the factory wiring even though does that help me considering i have another switch to install for the colour changing??? plus what switch would controll the fog lights??
Old Apr 6, 2008 | 05:06 AM
bert6573's Avatar
bert6573
I installed a set of fog light onmy bull bar....it the lights come with a kit, u dont need the factory switch, if anything that will make things more comlicated....trust me. if the fog lights have a kit the instal should not take more than 30 minutes at the most.......
