LSD problem????
Old Apr 5, 2008 | 09:45 PM
jperaino's Avatar
jperaino
Default LSD problem????
I have a 2008 1500 QC Laramie with the LSD. It only has 175 miles on it. When going around a tight corner the rear end chatters. Will this work out after a few more miles or do I have a problem that needs service, Any help will be greatly appreciated.
Old Apr 5, 2008 | 09:51 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: LSD problem????
hmm...might wanna give it a little bit yet....mine never did that, but my truck had about 200 miles on it when i bought it....i'd say if it doesn't work it's self out within the next 50 miles or so, i'd take it in...won't cost ya anything
Old Apr 5, 2008 | 10:43 PM
NYPANAMA42's Avatar
NYPANAMA42
I'm no expert, and i might be wrong. But it sounds like LSD fluid wasn't added to the Gear Lube......Again this is only a guess.
Old Apr 6, 2008 | 06:19 AM
HammerZ71's Avatar
HammerZ71
Yea, a chatter usually means no LSD additive (friction modifier) is in there. I'd take it in and complain. They'll probably dump a 4 oz. bottle in there and the sound will go bye-bye...
Old Apr 6, 2008 | 08:00 AM
VA4MEDS's Avatar
VA4MEDS
Definitely the additive. Had the same issue with a Chevy a few years back. Added the additive and it stopped immediately.
Speed Safely
AL
Old Apr 6, 2008 | 09:07 AM
sschevy400's Avatar
sschevy400
try this first....
Go to a parking lot at night and do some tight figure 8's....My truck did it too when i first got it...and after 3 min of figure 8's, it went away.
Old Apr 6, 2008 | 07:23 PM
jperaino's Avatar
jperaino
ORIGINAL: sschevy400
try this first....
Ok...thanks...I'll try it.
Old Apr 6, 2008 | 08:38 PM
RamItOne's Avatar
RamItOne
nobody thinks it a "c(u)nt clip"?
if you use amsoil you wont even need the friction modifier...
