Fan Clutch ?
Old Apr 6, 2008 | 03:44 PM
287cc's Avatar
287cc
Default Fan Clutch ?
I need help on ordering a fan clutch for my ram. But what is the difference in one having a heavy duty cooling and one without? Which do I order? My truck is 4.7L half ton 2wd
http://www.autozone.com/N,16300118/s...eResultSet.htm
Thanks in advance
Old Apr 6, 2008 | 04:01 PM
RamItOne's Avatar
RamItOne
Default RE: Fan Clutch ?
thought you had an E fan?
Old Apr 6, 2008 | 04:19 PM
287cc's Avatar
287cc
I do, but my efan controller went out. Im running my efan without a controller and dont want the battery to drain to much or any other problems to arise till I get everything running the 100% correct. Since autozone has the fan clutch in stock right now I will use that till I get the new controller.
Old Apr 6, 2008 | 04:41 PM
RamItOne's Avatar
RamItOne
Most 2k-3k cfm e fansa only draw 10 amps. The 4k plus can draw 50 amps but those are twin fans.
Seems like a waste of money when you could order the broken part and get it in a few days.
Old Apr 6, 2008 | 04:51 PM
daytona1680's Avatar
daytona1680
my e-fan draws almost 100 amps on start up and between 33-35 amps when running. I dont have the viper, but dont see how it would be much different...
Old Apr 6, 2008 | 05:17 PM
MikeHTally's Avatar
MikeHTally
ORIGINAL: daytona1680
You must go through some fuses. My Flex-a-lite fan kit came with a 40A.
Old Apr 6, 2008 | 05:18 PM
287cc's Avatar
287cc
RamItOne, I also want to have a fan clutch on hand for future use.The main reasonI switched to a efanwas because myoem fan clutchwentbad.
daytona1680, which efan are you running?
Old Apr 6, 2008 | 05:24 PM
RamItOne's Avatar
RamItOne
how many cfm does yours pull?
http://www.jegs.com/p/Flex-a-lite/752451/10002/-1/10117
twin fan, 4600 cfm 28 amp max draw
http://www.jegs.com/p/Flex-a-lite/754035/10002/-1/10117
3000 cfm 19.5 amp draw
Heres one for a ford power joker
http://www.jegs.com/p/Flex-a-lite/761953/10002/-1/10117
over 6,000 cfm with 28-36 amp draw..
Old Apr 6, 2008 | 05:38 PM
287cc's Avatar
287cc
Can anybody help me with my question?
Old Apr 6, 2008 | 05:42 PM
MikeHTally's Avatar
MikeHTally
ORIGINAL: 287cc
I guess we did deviate a bit. Man, I love being a deviate Anyway, it wouldn't seem to hurt to get the heavy-duty cooling version, and probably isn't a whole bunch more $
