Dodge Needs to Recall there EGR Valves
Old Apr 8, 2008 | 08:19 AM
  #21
daytona1680's Avatar
daytona1680
Default RE: Dodge Needs to Recall there EGR Valves
ORIGINAL: HankL
It should be recalled.
Your local small claims court will probably side with you against Chrysler and the dealership if you want to go that way.
The Emissons Warranty should cover ALL parts involved in pollution control
and in the end it is what the EPA officially says (or C.A.R.B in Ca)
not what Chrysler or the local dealerships says
that determines what parts are covered at no charge.
so whats cheaper? Going to court or paying the $40 for a new EGR
Old Apr 8, 2008 | 12:37 PM
  #22
Parts/Service's Avatar
Parts/Service
From the warranty manual.......For whats it worth
[align=left]5.1 Federal Emission Warranty[/align][align=left]A. Parts Covered for 2 Years or 24,000 Miles[/align][align=left]Federal law requires DaimlerChrysler Motors[/align][align=left]Company LLC ("DaimlerChrysler") to warrant the[/align][align=left]following emissions parts for 2 years or 24,000[/align][align=left]miles, whichever occurs first. DaimlerChrysler[/align][align=left]covers all of these parts under the Basic Limited[/align][align=left]Warranty for 3 years or 36,000 miles, whichever[/align][align=left]occurs first.[/align][align=left]• Air system controls;[/align][align=left]• distributor and its components;[/align][align=left]• electronic fuel injection system, including[/align][align=left]injector;[/align][align=left]• evaporative-emission canister and controls;[/align][align=left]• exhaust manifold;[/align][align=left]• exhaust gas recirculation valve and control[/align][align=left]system;[/align][align=left]• exhaust pipes (between exhaust manifold and[/align][align=left]catalyst);[/align][align=left]• fuel cap and tank assembly, pump, and fuel[/align][align=left]lines;[/align][align=left]• ignition coil and ignition module;[/align][align=left]• intake manifold;[/align][align=left]• on-board diagnostic-system components;[/align][align=left]• oxygen sensors;[/align][align=left]• positive crankcase-ventilation (PCV) valve or[/align][align=left]orifice;[/align][align=left]• secondary ignition wires;[/align][align=left]• spark plugs;[/align][align=left]• throttle body;[/align][align=left]• transmission-control module;[/align][align=left]• vacuum hoses, clamps, and fittings, as well as[/align][align=left]tubing used for these components;[/align][align=left]• vacuum, temperature, altitude, speed, timesensitive[/align][align=left]valves, sensors, and switches used in these[/align][align=left]components and systems.[/align][align=left]B. Parts Covered for 8 years or 80,000 miles[/align][align=left]If your vehicle has one of the following parts, this[/align][align=left]Federal Emission Warranty covers that part for a[/align][align=left]period of 8 years or 80,000 miles, whichever occurs[/align][align=left]first.[/align][align=left]These limits are counted from the time when your[/align][align=left]Basic Limited Warranty begins under 2.1(E). The[/align][align=left]covered parts are:[/align][align=left]• catalytic converter; and[/align][align=left]• powertrain control module.[/align]
