Need some help, truck is F-ing up.
Old Apr 10, 2008 | 01:46 PM
oefootball_70's Avatar
oefootball_70
Default Need some help, truck is F-ing up.
Okay, so my truck's radio will not turn off. even with the key out. and the door open chime is ringing when the keys are out and the door is open. Any help would be awesome.
oh, and the truck isn't throwing any codes.
Old Apr 10, 2008 | 01:51 PM
chopperzen's Avatar
chopperzen
Default RE: Need some help, truck is F-ing up.
Have you tried disconnecting the battery for a few minutes? Check the door too.
Old Apr 10, 2008 | 01:53 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
i told you not to let the stormtrooper near your truck. he done lightsabered you're fusing and stuff.
Old Apr 10, 2008 | 02:02 PM
StevenMoffettKY's Avatar
StevenMoffettKY
Yeah, I'd have to agree with disconnecting the battery.
Old Apr 10, 2008 | 04:08 PM
oefootball_70
ok, the battery thing isn't working. this sucks a lot
Old Apr 10, 2008 | 04:15 PM
De pinga!'s Avatar
De pinga!
Sounds like an electrical problem in my suggestion. Maybe it has to do with the push start somehow? since your radio stays on and truck rings like the keys are in i would imagine it thinks the keys are in... May be something with the push start dont know exactly.
Old Apr 10, 2008 | 05:38 PM
oefootball_70
I have had the push button for 2 years and it hasnt done that yet.
it finnaly threw some codes
p0645
p0627
p0462
Old Apr 10, 2008 | 05:51 PM
oefootball_70
well **** these dont sound good.
P0645 A/C Clutch Relay Control Circuit
P0627 Fuel Pump "A" Control Circuit Open
P0462 Fuel Level Sensor Circuit Low Input
Old Apr 10, 2008 | 05:59 PM
RamItOne's Avatar
RamItOne
does your radio turn off when you push the off button on the radio.
As for it thinking the keys are in the cig lighter on the left goes off when the keys aren't in, try hooking up something to that and turn the truck off and see if the device is still getting power.
Old Apr 10, 2008 | 06:02 PM
oefootball_70
ok, ramit i kinda understud what u said. but no really/ and yea the radio turns off.
