Need some help, truck is F-ing up.
Old Apr 11, 2008 | 02:33 AM
  #21
MegaDual's Avatar
MegaDual
Default RE: Need some help, truck is F-ing up.
Inverters have capicitors within them. If not wired correctly or as some pointed out into your lighter sockets it will keep some stuff powered up. I still say start with the basics. Check ALL the fuses, check all the main grounds starting at the battery, and make sure if you recently added something that all connections are clean. You might be getting water down the a-pillar into the wiring but you'll go astray if you start there. Start with the easy stuff before you go tearing your truck apart.
Old Apr 11, 2008 | 02:35 AM
  #22
RamItOne's Avatar
RamItOne
kinda like checking the coolant level before you go replacing the water pump...
Old Apr 11, 2008 | 09:56 AM
  #23
oefootball_70's Avatar
oefootball_70
okay, I can't start working on it till sat. but I don't even know how much time I will have.
Old Apr 11, 2008 | 12:48 PM
  #24
oefootball_70
Okay, so dumb truck. It works perfectly fine now.
Old Apr 11, 2008 | 02:14 PM
  #25
hollywood703's Avatar
hollywood703
well if it works perfectly now, it would lead me to the lights leaking a bit of water....now that the water has dried, it is corrected.....might pull them off and look for condensation, or corrosion to make sure it isnt that......
Old Apr 11, 2008 | 05:34 PM
  #26
oefootball_70
okay, well now something else is wrong. It feels like I am driving a tractor and it threw this code P0700 Transmission Control System Malfunction any advice
Old Apr 11, 2008 | 11:34 PM
  #27
whiteonrice's Avatar
whiteonrice
Time to sell.
Old Apr 11, 2008 | 11:37 PM
  #28
mmstar23's Avatar
mmstar23
ya thats not good.....the guy thats stuck in 2nd gear threw the same code.
Old Apr 11, 2008 | 11:48 PM
  #29
oefootball_70
****, thats what is happening to me unless if I **** manually.
Old Apr 12, 2008 | 12:01 AM
  #30
mmstar23's Avatar
mmstar23
ya....check out that post, your having the same problem
