removing cats
Old Apr 30, 2008 | 11:48 AM
KrazyBrian's Avatar
KrazyBrian
Default RE: removing cats
you can, let me know where you find the o2 simulators
Old Apr 30, 2008 | 03:17 PM
mmstar23's Avatar
mmstar23
what exactly is an o2 simulator and how does it work/connect/install?
Old Apr 30, 2008 | 07:10 PM
HammerZ71's Avatar
HammerZ71
Last I heard of simulators being bought, they were about $75 each. Do the $5 non-fouler trick instead. I've even heard from some that the simulators threw a code, but the non-foulers didn't.
And you must have cut the resonator, because if you ditched a cat, you'd have had instant code...
Old Apr 30, 2008 | 07:25 PM
Barb3r's Avatar
Barb3r
I had a maxima which had a bolt on cat.After 90k it was sluggish so i unbolted it and used a air chisel to knock everything out of
the inside.Bolted it back up so it could still pass inspection and noticed a huge difference.I was hoping to do that to my dodge untill i saw there were
no bolts.Too bad i dont know how to weld.
Old Apr 30, 2008 | 08:44 PM
Timmerduder's Avatar
Timmerduder
Don't most places have DEQ where if you remove the cats the truck won't be able to be licensed?
Old Apr 30, 2008 | 09:56 PM
stratusguy02's Avatar
stratusguy02
The cats are covered as an emission item under warranty. They should be covered for 10yrs/100k I think. check your manual for confirmation for your truck. If so, the dealer will replace them for free.
Old Apr 30, 2008 | 10:11 PM
mmstar23's Avatar
mmstar23
thanks hammer, but can you lead me through instructions on the non-fouler trick. maybe a DIY?
ill call dodge tomorrow and see about the warranty on the cats
Old Apr 30, 2008 | 10:47 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: mmstar23
Jeesh, did you grow up in a box?
https://dodgeforum.com/m_1295926/mpa...tm.htm#1295926
Old Apr 30, 2008 | 11:05 PM
mmstar23's Avatar
mmstar23
haha....a very nice box
im sorry hammer, i dont know the non fouler trick...." JEESH" hahaa
Old Apr 30, 2008 | 11:09 PM
mmstar23's Avatar
mmstar23
in the DIY it says 2 sets....i need 4 considering that theres a 02 sensor before and after the cat on both sides, and i need 2 non fouler plugs for 1 o2 sensor
