what the hell is wrong with me???
Old May 1, 2008 | 08:24 PM
tigman250's Avatar
tigman250
Default what the hell is wrong with me???
i recently bought a 06 Hemi Ram, ever since then i have had this need to modify it and make it my own.....
it started with a Bully Dog downloader and a CAI, now i want to lift it 3", unfortunatly all the body lifts i have seen require you to hack the fan shroud and add spacers to accomidate the additional 3". i am unwilling to do this, so i have purchased a Mark VIII electric fan and plan to ditch the stock clutch fan. i have done all the research on the fan and install but i am wondering why the thermostat switches only have one terminal on them? aren't they just a normally open contact? if so dosen't that require 2 terminals? an in and a out LOL what am i missing? all of the schematics i have run accrost seem to utilize a 2 terminal thermostat also. someone please enlighten me!
EDIT- what would be a good temp to kick the fan on? 200 mabey 210 degrees?
every peoject i do to my truck seems to snowball, i wanted a lift but don't want to cut my shroud all up, so i decide to do an electric fan, after i remove the shroud i won't have any place to hang the coolant and windshield washer containers, looks like i have to make make something for that too
Old May 2, 2008 | 04:17 AM
Mr Edison's Avatar
Mr Edison
Default RE: what the hell is wrong with me???
The switch has only one terminal is that it switches to ground. Positive lead to one side of fan.Other fan lead goes to the switch . Switch is turning on the fan ground to complete circuit.
Old May 2, 2008 | 06:58 AM
MikeHTally's Avatar
MikeHTally
My Flex-a-Lite kicks on at the old "normal" temperature (probably 203). Your fan controller should have several terminals: one from the relay, two for the battery connections, two for the fan motor, one for a manual override, and one for the A/C sensor. Yes, unknown to the general public, there is a chemical released into the cab upon signing on the dotted line. This chemical causes an uncontrollable urge to mod. Be prepared for a wrestlin' match gettin' the fan clutch off the water pump pulley. You can get a gadget that will grip the pulley or you can get a BFH to whack a big crescent wrench.
Old May 2, 2008 | 07:11 AM
HammerZ71's Avatar
HammerZ71
Don't ditch your shroud! I was going to when I installed my Flex-a-Lite 180 and was advised by guys at the local performance shop that without the shroud to direct air flow, it would be bad.
Also on their advice, I set my fan to come on just before (about 3-5 degrees) the thermostat temp, in my case, 180*...
Old May 2, 2008 | 12:46 PM
SmokeySportRam's Avatar
SmokeySportRam
yep, it dont take long to get bit by the mod bug, problem is when you start doing it to multi cars.
takes $$$
Old May 2, 2008 | 03:40 PM
MikeHTally's Avatar
MikeHTally
You shouldn't have any issues taking the shroud off. I left mine on'cause I didn't want to have to re-mount the washer bottle and coolant recovery tank. The existing shroud has nothing to do with redirecting airflow... the e-fan has its own shroud to be sure it pulls air through the radiator.
Old May 2, 2008 | 05:08 PM
tigman250's Avatar
tigman250
any opinions on the type of sending unit to use? are the screw in's more accurate than the push in probes? do you just insert the probe in between the fins of the radiator?
Old May 3, 2008 | 02:57 PM
blackram5.9's Avatar
blackram5.9
stay away from body lift!!!! go get a torsion bar lift. also a three inch lift whole lot easier to install and less problems!!
Old May 3, 2008 | 06:00 PM
tigman250's Avatar
tigman250
ORIGINAL: blackram5.9
i have to go body lift if i want to raise it, i have the lifetime drivetrain warranty and i believe anything but a body lift would void it. plus i don't like pushing the fronttires of a 4wd with IFSdown without moving the center chunkdown because of the radical driveline angles produced......exactly why i think it would void my warranty.
BTW 05 was the last year Dodge put torsion bars on Rams
Old May 3, 2008 | 08:05 PM
ivaskaj's Avatar
ivaskaj
It will only void the suspension warranty, not the powertrain warranty. That's what my dealer told me, anyway.
