lifting your truck
Old May 3, 2008 | 09:56 AM
Mopar2511's Avatar
Mopar2511
Default lifting your truck
ok this is going to be a stupid question... but i want to lift my truck a bit, is there a difference between a body lift and a lift kit? because a lift kit includes a whole new suspension, but the body lift is just lifting the body and not doing anything to the suspension right? i know its a stupid question.
Old May 3, 2008 | 10:19 AM
HammerZ71's Avatar
HammerZ71
Default RE: lifting your truck
The "Search" feature is a wonderful thing...
https://dodgeforum.com/m_1267450/tm.htm
Old May 4, 2008 | 08:30 AM
HEMI07's Avatar
HEMI07
a body lift is a lift kit too...just a different type. A suspension lift kit lifts a truck using suspension components and a body lift lifts a truck using spacers between the body and the frame.
Old May 6, 2008 | 12:22 AM
irelandshemi's Avatar
irelandshemi
how high can i get my truck usign a bodylift before it looks wierd with the bumpers, im assuming it would be the same as my jeep where i raise the body and the bumpers stay the same height
Old May 6, 2008 | 12:36 AM
Romeosoldier03's Avatar
Romeosoldier03
well...with my body lift and level kit and 36's......measuring from the bottom of the middle of the fender to the ground is 46 1/2" and 47" in the rear, I sit about 1/2" taller than most 6" suspension lifts.........
Old May 6, 2008 | 12:40 AM
irelandshemi
so what size body kit should i do if im rocking stock tires and 17's right now which will one day be bigger (side note, anyone have any ideas the biggest tire i can fit on the stock tire)
Old May 6, 2008 | 07:34 AM
HammerZ71's Avatar
HammerZ71
I believe the only choice for the 3rd gen Ram's in a body lift is 3". The better kit's come with bumper relocation brackets, so you'd not have a problem there.
Old May 6, 2008 | 11:53 AM
Scott06HEMI's Avatar
Scott06HEMI
3" kit from performance accessories comes with the brackets to move your front and rear bumpers up and I don't think you can go over a 35" tire with out problems. Not sure if 17" rims makes a difference in that statement though.
Old May 6, 2008 | 03:07 PM
irelandshemi
thanks
