how to remove tmc look!!!!
Old May 4, 2008 | 08:25 PM
killerbud420's Avatar
killerbud420
Default how to remove tmc look!!!!
on certain late model d.c. trucks(01 to 03) i think 3.7 4.7 5.7hemi
torque management uses atorque sense wire.the wire can be disabled to prevent the pcm (powertrain control module) from reducing torque at wot he says he can chirp 2nd after doin this
Old May 4, 2008 | 09:22 PM
killerbud420
Default RE: how to remove tmc look!!!!
i know mine is an 04 but im sure it has it to im thinking about when i getmy truckback making a switch for it that i can cut it on an off in thetruck for at the track..hope i dont **** my truck upeverybodys tells me i need a tank
Old May 4, 2008 | 10:27 PM
daytona1680's Avatar
daytona1680
ORIGINAL: killerbud420
yoursdosn'tThis mod for for 03 and earlier trucks only. Only way to reduce TM on 04 -up is superchips, and eventually SCT will have that feature also
Old May 4, 2008 | 10:48 PM
killerbud420
****...how muchbettter is your 260 cam then a 6.1 an did it help your 0 to 60
Old May 4, 2008 | 10:58 PM
daytona1680
260 puts out more tq than a 6.1, hp is about the same between the 2 cams. I never really pay attention to my 0-60 so I dont know how much better it is. All I know is when I take off from a stop the truck takes off like a rocket if I keep traction( have to play with the peddle a little until it hooks up).
Old May 4, 2008 | 11:42 PM
De pinga!'s Avatar
De pinga!
i have an 03 4.7... you mean by disabling that cable i can get more torque safely? how sure are you about this...
Old May 5, 2008 | 12:21 AM
daytona1680
ORIGINAL: De pinga!
From what I hear from the people who do it there is nothing safe about it, this is why I never had superchips send me the update to reduce TM; I dont have the money to have my tranny rebuilt at the moment.
Old May 5, 2008 | 12:50 AM
Ben D.'s Avatar
Ben D.
I dunno if this is a safe thing to do.the biggest weak link in the chrysler 545rfe transmission is. it is the second gear clutches and assembly. at WOT downshifts is the easiest way to toast that tranny by just massacring the second gear. there is a reason that torque is decreased at WOT
Old May 7, 2008 | 02:18 PM
De pinga!'s Avatar
De pinga!
Damn... gave my hopes up.
Old May 7, 2008 | 02:31 PM
John  M's Avatar
John M
This was news 5 years ago; it's been common knowlege on all the Dodge boards -- I assumed even here. There are plenty of how-to's to do this mod.
The Superchips programmer does the same thing which is why I never bothered to cut the wire.
