To supercharge or not to supercharge?
Old May 9, 2008 | 11:04 PM
whiteonrice's Avatar
whiteonrice
Default RE: To supercharge or not to supercharge?
Probably cost another $1,000 to $1,500 to have it installed and tuned correctly. It's pretty hard to control yourself when you have the power your truck is going to have. I don't think it's going to help your trans situation. Pro Chargers are internally lubricated. I have one on my Corvette.
Rick
Old May 10, 2008 | 01:24 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: deerjunkie
Aren't Powerdynes internally lubricated? Where others like Procharger get lubrication from the engine oil, which I prefer....Just something to think about.
It's the other way around...
Old May 10, 2008 | 10:28 AM
05Redram's Avatar
05Redram
If you can find someone to tune it for a reasonable price then I would get it.
Old May 10, 2008 | 05:55 PM
atlaticblueram's Avatar
atlaticblueram
the computer will not need tuning when i install it it comes with a fmu and new fuel pump when the super charger hits 3 psi of boost the fmu allows more fuel pressure thus allowing more fuel per injector pulse. tuning is not needed according to powerdyne since it is only 6psi of boost
Old May 10, 2008 | 05:58 PM
atlaticblueram
also it doesnt matter if the website says fits 96-2001 the 360 has not changed neither did the pcm in the 2002 it has the same programming as the 2001! all i have to do is relocate my igniton coil
Old May 10, 2008 | 07:27 PM
oefootball_70's Avatar
oefootball_70
****, thats so tight man. Do it.
Old May 11, 2008 | 09:25 AM
djr04's Avatar
djr04
Plus, you'll still be able to tow with that supercharger. Turbos on our gassers while towing can cause some really high EGT's. (Although I would still put in a pyrometer to keep track of the EGTs on the SC, just to be safe)
Old May 12, 2008 | 06:56 PM
atlaticblueram
egt's wont be a problem with the supercharger since it is ran with a belt and not by the exhaust but good looking out djr04. i will be running an air fuel ratio gauge boost gauge and tranny temp gauge to make sure i dont get the tranny too hot!
Old May 15, 2008 | 10:58 AM
atlaticblueram
putting the supercharger on tonite hopefully!!!
