cruise control not working
Old May 10, 2008 | 11:56 PM
DaytonaGrl24's Avatar
DaytonaGrl24
Default cruise control not working
I drove to a friend's house today, cruise was working fine. 5 minutes later i was leaving my friend's and doing about 67mph and cruise would not kick in. it was on and the light said CRUISE on the dash but i kept trying to set it and i'd let go of the gas and it would just start to slow down, nothing would make it work. i tried about 3 times. the check engine light is on also but for a different reason-O2 sensor or vacuum leak not sure yet which. but the cruise had been working the whole time it's been on except for today. any ideas?
Old May 11, 2008 | 12:04 AM
quadr8cr08's Avatar
quadr8cr08
Default RE: cruise control not working
Mine did this one time. I took mine to the dealer, I had other problems as well, but I can't remember what exactly it was. It was nothing major though. Check your fuses.
Old May 11, 2008 | 07:25 AM
quadzilla's Avatar
quadzilla
I had this issue on my 04 and it turned out to be the brake switch under the dash. I notice that my brake lights were on all the time. You can get a replacement from you local parts store for under $20 and install it yourself. Good luck.
Old Mar 13, 2009 | 06:47 AM
Rudiger528's Avatar
Rudiger528
Default yut
my buddy has an o4 ram and his cruise control doesnt work either youll be driving down the road and itll just shut off. I didnt think about that switch until you mentioned it quadzilla. another problem he has been having is his taillights flickering on and off so maybe replacing that switch is a way to kill two birds wth one stone.
Old Mar 13, 2009 | 11:20 AM
truckin151's Avatar
truckin151
Had this with my 05', do a quick check for codes, I had a p2222 or something like that which was a speed sensor or something of that nature. I would clear the code and the cruise control would work fine but the second the code came back it stop working again. I dont really know how I fixed it exactly, but I had to take it down to get the brakes fixed at a shop down the road from us and since then the code has not popped back up and the cruise control works fine...
Old Mar 13, 2009 | 11:30 AM
jonnymagnum's Avatar
jonnymagnum
mine had a code like that probly about a month after I bought it and the cruise control woudnt work, I dunno what they did at the dealer, but its worked ever since.
Old Mar 13, 2009 | 05:20 PM
Rudiger528's Avatar
Rudiger528
how do you check codes?
Old Mar 13, 2009 | 05:32 PM
truckin151's Avatar
truckin151
Turn your key on and off 3 times (I think its 3) repeatedly but dont start the truck and you'll hear a beep like when you are driving without a seat belt on. If your truck has a problem a code should pop up where your odometer is in the dash. If it doesn't it'll just say done and go back to the odometer reading.
Old Mar 13, 2009 | 09:24 PM
jonnymagnum
yup, just turn the key on-off-on-off-on and then the code will apear in the odometer reading
Old Mar 13, 2009 | 10:37 PM
WhiteBerry's Avatar
WhiteBerry
whats the brake switch? where under the dash is it? pics anyone???
