4.10 gears on a 4.7l?
Old May 12, 2008 | 11:17 AM
tizzle0469's Avatar
tizzle0469
Default 4.10 gears on a 4.7l?
ive got an 07 4.7l, thinkin about some gears, what is everyones opinion on gear size keeping gas milage in mind too. i was thinkin 4.10's tell me what yall think
Old May 12, 2008 | 11:43 AM
HammerZ71's Avatar
HammerZ71
Default RE: 4.10 gears on a 4.7l?
My personal rule of thumb is for stock size up to about 32.5" tires, the 4.10's are ideal. Gives you the best balance of power and fuel economy. Anything at 33" or over and 4.56's would be the best choice.
If you currently have 3.55's then a switch would be highly recommended. If you currently have 3.92's, I don't know if you'd see a big enough difference to justify the cost if you went to 4.10's. I went from the stock 3.92's to 4.56's after lifting and going to 35" tires and the difference was night/day...
Old May 12, 2008 | 12:29 PM
tizzle0469's Avatar
tizzle0469
YEA, I HAVE STOCK 3.55'S, ANYONE KNOW ABOUT WHAT THAT WOULD RUN? GEARS AND INSTALLATION?
Old May 12, 2008 | 02:14 PM
senselesscreationz's Avatar
senselesscreationz
would 4.56's make a difference with 35's? i have 3.92's right now and it is sluggish as hell. if so where would be the best spot to get the new gears and what brand?
Old May 12, 2008 | 02:59 PM
bradsalex's Avatar
bradsalex
How do I find out what gears my truck has. I have an '05 1500 QC 4x4 4.7
Old May 12, 2008 | 03:54 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: senselesscreationz
A search of this topic would probably get you hundreds of hits. The "what gear ratio/what brand" thing makes it's way back to the forefront of this (and most) forums about once a month.
That said, I don't think any one name brand is significantly better than another. This mod is ALL about the installation. This is one you need to find a qualified shop/tech and pay their price to have it done right. Setting gears is not easy, especially in the Chrysler Corporate (AAM) axles, and needs to be done by someone with experience at it.
Popular places to purchase are: Moe's Performance, Air Ram, Randy's Ring & Pinion & 4 Wheel Parts. Google them for the link...
Old May 12, 2008 | 07:44 PM
oefootball_70's Avatar
oefootball_70
I have 35 on a 4.7 with 4.56 I moved from 3.55 gears. It was awesome. I dont even notice that I moved up in tire size.
Old May 13, 2008 | 11:54 AM
superdak05's Avatar
superdak05
if you open up your glove box and on the back panel there should be a sticker with that info, if not call your local dealer and give him your vin number. also i had the 3.55 in my 4.7 dakota, switched them out for towing purposes and what a big difference it made around town, gained about two miles to the gallon and pretty much stayed the same on the interstate. my swap ran me about 1600.00 for gears, bearing kit, axle seals, oil, labor, tax. 4 x 4 ,
Old May 13, 2008 | 12:32 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
yay! let's make another thread about this, and then we can stack all three 3rd gen index!!!
Old May 13, 2008 | 03:43 PM
HammerZ71's Avatar
HammerZ71
Yea D-man, I'm thinkin' the gear issue needs to be a sticky, so we can just refer all these guys to the top of the page...[&:]
