Transmission is a NO-GO
Old May 24, 2008 | 06:24 PM
ron45640's Avatar
ron45640
Default Transmission is a NO-GO
I have an 04 ram w/4.7 and auto tranny and I was driving today and the truck felt like somone just put into neutral. I pulled off the road and tried and it will not go into any gear. The only code it thru was the P0700 code in the odometer. Any one have any ideas??? Tranny gave no sign of anything wrong . I changed the fluid and filters about a month ago. Hope someone can help me
Old May 24, 2008 | 06:58 PM
ron45640's Avatar
ron45640
Default RE: Transmission is a NO-GO
Help me
Old May 24, 2008 | 07:12 PM
Horseapples's Avatar
Horseapples
sorry bro, I have no idea
Old May 24, 2008 | 07:16 PM
Horseapples
OK, I did a search on here for the code and this is what i came up with
"I had the same problem with my truck with only 500 miles on the odomenter. It's a computer control module located in the transmission. Take it to the dealer and they will drop the pan, replace the module, and refill the transmission. "
That was a reply to another guy about the same code. You can search at the bottom of the page and read the replies yourself, there are several. Hope this helps
~Mitch~
Old May 24, 2008 | 07:57 PM
HammerZ71's Avatar
HammerZ71
P0700 is a generalized transmission sensor error. From whatI just read, over half the time this code pops it is that the tranny fluid level is low. Check the level before you call the dealer, may be as simple as that...
Old May 24, 2008 | 08:15 PM
73Jim's Avatar
73Jim
I had a coworker with a 4.7 auto truck and when Pep Boys changed his trans fluid they put his filter on backwards. About 2000 miles later his trans wouldn't engauge. He took it to the dealer, they put a new filter in the trans and everything was fine. Sounds similar.
Old May 24, 2008 | 08:45 PM
ron45640's Avatar
ron45640
I checked the fluid everything looks good , But when I did change the filter I just put the o-ring on the filter and pushed it in. I read where it is important to fully seat the grommet. I will check first thing in the morning. Thanks for the replies i will let you know tom.
Old May 24, 2008 | 09:58 PM
Horseapples
make sure the old o ring is out of the valve body also. If your filter is laying in the pan this is probubly whats wrong
Old May 24, 2008 | 10:30 PM
HammerZ71's Avatar
HammerZ71
Horsey, Congrats man, 1000th post!!!
And less than 900 of them were the good old "+1" type too...
Old May 25, 2008 | 03:19 AM
Horseapples
Ha! I just noticed that! sweet, A new mile stone!
